oem water pump?
oem water pump?
so rockauto lists two part #s for the ac delco water pumps..anybody know the difference between these two besides the impellar one is $106 and the other is about $180..this is what rockauto told me
"Thank you for your email. The 251744 is the Original Equipment (OE) design with a steel impeller that Pontiac/GM used originally on the vehicle. The 252846 is the aftermarket replacement version with a cast iron impeller"
i ran into this problem back when i changed my waterpump. they (gm) discontinued the ls1 pump so only ls2 was available for me. as the other poster stated i needed a diff housing which meant a diff 160 therm. new pump bolted up just fine. cheers!
talked to a GM dealer, ls1 pumps are updated which like you said is pretty much the ls2 pump..so I would need the ls2 housing and two new bolts..so does that mean I use the thermostat from the ls2 as well aka gto?
