what are the best spark plug wires to use
Old 05-09-2004, 07:18 PM
DaveC's Avatar
Default what are the best spark plug wires to use
which wires are the best to get ? how much do they cost ? where can you get them ? what should the wires ohm out at ? need help
Old 05-09-2004, 07:42 PM
Cheatin' Chad's Avatar
Pretty much anything the sponsors sell would be adequate. Stock replacements seem to work just as well as aftermarket.
Don't expect to make power off of these unless your current wireset is failing.
I use MSD. Just because I have been using their products for years without issues.
Taylor,Magnecor and others make good products as well.
Figure $50-100+ for wires.
good luck.
Old 05-09-2004, 09:54 PM
Sniper33's Avatar
MSD's no problems.
Old 05-09-2004, 10:20 PM
Ryan02SS's Avatar
MSD's here. FYI my stock 02 wires with 12,000 miles on them had .725 thousandths ohms of resistence while the MSD 8.5s had .025 thousandths ohms. That alone will tell you your getting a better spark with the MSD's.
Old 05-09-2004, 11:05 PM
SidewayzOZ's Avatar
I think most ppl will agree that wires are wires. As long as you dont buy something that was hand made by a blind guy it should be fine. MSD, Taylor, Magnecore, whatever.
Old 05-09-2004, 11:13 PM
Ferocity02's Avatar
Whatever is within your budget and the color you want will determine which wires you get. I got the Taylor '409' Pro Race wires because they were the largest I can find, 10.4mm and they came in red which looks really nice under the hood.
Old 05-10-2004, 02:58 AM
pdd
pdd's Avatar
MSD here
Old 05-10-2004, 06:52 AM
DubJ's Avatar
Yeah Dude I got the MSD's as well.My car is red and I got the red wires. Looks sweet under the hood!
Old 05-10-2004, 10:21 AM
SSCamaro99_3's Avatar
MSD Superconductors, no issues so far.
Old 05-10-2004, 06:56 PM
DaveC's Avatar
thanks for the input. the MSD wires that are on the car ohm at .1 to .56 . car stumbles a little I am not going to drive it till i replace the wires.
Old 05-10-2004, 07:28 PM
PSU_Engineer's Avatar
Delphi Red Wires.
hey, they came with the car. The previous owner had the dealer put them on when he bought it.
Tony
Old 05-10-2004, 08:15 PM
ynkssws6's Avatar
I like the Taylor Spirals. You can get them in a lot of colors, so what ever floats your boat. My dad has MSD, they're both great.
Old 05-10-2004, 08:54 PM
FstBlkz28's Avatar
i've got Accel 9000's .... no issues whatsoever.... if had to go back and do it again ... i mighta gotten a cheaper set of wires. But i don't regret getting the Accels
Old 05-10-2004, 09:05 PM
AgentOrange's Avatar
MSDs here too.
Old 05-10-2004, 09:53 PM
10 & 11 Second Club
Caveman's Avatar
I used MSDs for a while but they came loose from the plug 2 different times at the dragstrip. Another racer told me the GM Performance wires are better. Same specs as the MSD wires but they click twice when you put them on so you know there on and they don`t slip off, and there red also.
Old 05-11-2004, 12:02 AM
Zero2Sixty's Avatar
GMPP in red.
Old 05-13-2004, 10:55 AM
WILWAXU's Avatar
I've used MSD & red GMPP. Both worked well.
