Need a favor from someone with a Helms manual
Hey guys,
Anyone with any year Helms manual, can you look up the fog light switch diagram for a Camaro? It should show a connector end view with the 6 pinouts along with the colors and function of each wire. It should be in the first volume, under Lighting Systems (look in the back for Fog Light Switch and it will give you the actual page) If you can scan it, take a picture of it, or even type it out, that would be great.
I have the 98 second edition Helms manuals and it is incorrect. For the diagram, it shows an 8 pin connector instead of a 6 pin connector, and the colors are wrong anyway. I literally went through the volume page by page looking for the right diagram. I know for sure that it's wrong, because I previously had a 2000 Camaro (and 2000 Helms manuals) and it had the correct fog light switch diagram.
I use the fog light switch as an anti theft measure btw, wired to disable the car. Factory switch, hidden in plain view. Sneaky sneaky.
Thanks guys.
Dope
Thanks guys.
Dope
Moderator
In my '02 manual it shows different connectors for
Camaros and 'birds. Pg 8-240, Lighting Systems:
Chevrolet Pin, Wire Color, Function
A, LtGrn, Headlamp Ground (Ckt 11)
B, Blk, Ground (Ckt 650)
C, Gry. Instrument Panel Supply Voltage 1 (Ckt 8)
D, N/A, Not Used
E, Brn, Park Lamp Supply Voltage (Ckt 9)
F, Yel, Fog Lamp Relay Coil Supply Voltage (Ckt 317)
Pontiac Pin, Wire Color, Function
A, Yel, Fog Lamp Relay Coil Supply Voltage (Ckt 317)
B, Ppl, Front Fog Lamp Supply Voltage (Ckt 34)
C, N/A, Not Used
D, Brn, Park Lamp Supply Voltage (Ckt 9)
E, N/A, Not Used
F, Gry, Instrument Panel Supply Voltage 1 (Ckt 8)
G, Blk, Ground (Ckt 650)
H, N/A, Not Used
D, N/A, Not Used
C, N/A, Not Used
E, N/A, Not Used
H, N/A, Not Used
