LS1 / LQ4 Alternator Question
Can you use a 6.0 truck 130amp alternator like for a 2000 2500hd on a 1998 z28 LS1 5.7? I need to replace mine and they are about the same price. The camaro alt. Is 105 amps the thr 2500hd is 130 amps.So I was just wondering if it would work.
I was looking at doing this on my 99 2500 4x4 since I built a dual electric fan setup for it. I was told you had to use a bigger charge wire to avoid burning the wire up at full draw.
