Intake manifold ?'s
Intake manifold ?'s
So I have been doing some research and I am trying to see if putting a different intake manifold on my truck is worth it. I have spent the past 4 hours searching about this.
-I would like the Fast lsxrt but lets face it, way to much.
-Holley high ram maybe? not enough info on if its worth it.
-Then the ED high ram?
I am in the process of doing a cam swap right now. I already have Long Tube headers, Tune, and CAI. The truck is a 2011 sierra 5.3l LC9 cathedral ports.
I am kinda of leaning towards the Holley High Ram, but just could not get enough info on whether or not its a good choice.
I am also trying to find out if i can use my stock truck injectors with this? I know I have to use the different fuel rails.
Any of you guys have a suggestion?
what cam did you install ?tell us alot more about your truck .a ls truck intake flows pretty good up to 5500rpm.you can find a used BBK intake for $300 ,flows a little better then a ls6 intake .
If you spend most of your time below 5k the stick with the truck intake manifold. You can also have it ported, which it will nicely benefit from.
http://peakspeedshop.com/Zen_Cart/in...705b5bd78d9c38
