6.0L LS6 Upgrade
Old 02-19-2014, 05:23 PM
bones5133's Avatar
Default 6.0L LS6 Upgrade
2003 6.0L LQ4 in a street rod.
I put a LS6 intake and want to use all of the original brakets. I have already cut and modified the alternator and power steering bracket to fit.
Has anyone used a 2007 or newer water pump to solve the issue of the top hose hitting the throttle body?
Thanks
Old 02-20-2014, 06:37 AM
bones5133's Avatar
No one knows if the later model water pump will work without too much modification?
Old 02-20-2014, 07:05 AM
3GZJerry's Avatar
Just use a fbody water pump. It will fit lq4 and come out the front.
Old 02-20-2014, 07:24 AM
garys 68's Avatar
If it's a DBW TB, no the newer angled outlet pump wont work. Only the smaller 07+ DBW TBs clear. If it's a cable TB, you can clearance the pump neck.
Old 02-20-2014, 07:35 AM
bones5133's Avatar
Yes it is the 03 TB.
The f-body waterpump will require spacers from what I have read?
Can you switch pulleys on the water pump from the truck to the f-body pump.
by using the spacer just seems like more spots to leak.
Old 02-20-2014, 10:21 AM
garys 68's Avatar
You can put a truck pulley on an f body pump that has a bolt on rear plate (not the press on). I've done several, you'll need a press. If you go that way, email me for details.
Old 02-21-2014, 04:10 PM
LS1MCSS's Avatar
Here is a truck engine with LS6 intake and 07 truck water pump. If your throttle body is different, use a 2010 camaro pump. It has the same spacing as a truck pump and a front exit.
Old 02-22-2014, 04:25 PM
bones5133's Avatar
I went with the spacers and a Camaro water pump.
Didn't you have to relocate the idler pulley on the alternator/power steering bracket?
I see there is one down low below power steering how did you mount it there?
Old 02-23-2014, 06:20 AM
garys 68's Avatar
I did the same thing to get a little more wrap on the pulleys. Not sure if it's absolutely necessary. Just use a spacer and a longer bolt in one of the PS/alt mount bracket bolt holes. Btw, you'll need the f body tensioner to get everything spaced correctly.
Quick Reply: 6.0L LS6 Upgrade
