4.8 heads on 6.0
Old 02-24-2014, 03:51 PM
Jones618's Avatar
Default 4.8 heads on 6.0
Is it possible to run 4.8l heads on a lq4 and what are the advantages for this. Obviously it would boost compression but is it a direct swap and would u see a descent hp gain
Old 02-24-2014, 05:42 PM
joshua022's Avatar
It will boost compression and is a direct swap, BUT it will cause valve shrouding because of the small combustion chambers on the larger bore.
I personally I wouldnt waste your time and money swapping them.
Old 02-24-2014, 07:19 PM
redtan's Avatar
Not anymore shrouding that takes place on the original bore, so that's not an issue.
They will however lose power or be just about even with 6.0 heads, so it's not really worth it unless you port them.
Old 02-24-2014, 07:52 PM
13 Second Truck Club
726.0chevelle's Avatar
you will gain compression with any set of 4.8 heads but if its the 06 or earlier you will lose flow because of the smaller valves and runners. The only 4.8 heads Id put on a 6.0 is the 07 and later 799 or 243 casting heads.
Old 02-25-2014, 02:26 PM
JRENIGAR's Avatar
This...
Old 12-21-2018, 07:20 AM
Joelynn Carter's Avatar
will you gain torque from the larger 6.0 pistons?
Old 12-22-2018, 06:14 PM
Received 3,021 Likes on 2,352 Posts
4.8 heads are the same as 5.3 heads of the same years. Putting them on a 6.0 will just choke it. As above, 243/799 heads will do you the most good on a 6.0
Old 10-30-2019, 10:06 PM
Paper Man's Avatar
Yup. Sloppy Mechanics used 799 4.8 heads on this 6.0 with just a cam and I forget what injectors. Impressive for something so simple. The ultimate budget way to wake up a tired 6.0 it seems.
Old 10-30-2019, 10:57 PM
https://www.youtube.com/watch?v=HodXYJR0Zxo
Gotta be careful here. Only the Gen IV 4.8/5.3 engines have the 799/243 heads. The Gen III 4.8/5.3 used the 706 heads.
Old 11-03-2019, 01:38 PM
"I MAID THEESE"
Mavn's Avatar
706 heads FTW !
The following users liked this post:
G Atsma (11-03-2019)
Old 11-03-2019, 01:47 PM
Originally Posted by Mavn
706 heads FTW !
Yep, they seem to be proving their worth after being trashed for so long.
Quick Reply: 4.8 heads on 6.0
