NGK TR55-IX Spark Plugs Gap
Old 02-26-2014, 11:39 PM
rjla67's Avatar
Default NGK TR55-IX Spark Plugs Gap
I picked up a set of NGK TR55-IX Spark Plugs from WS6Store that states that they are gapped for .060. I have a 1998 Z28 and the under hood info label says gap at .060, but I see lots of conflicting info on what they really should be so they are sitting on the workbench for now. Anyone have the answer to what I should gap them or just leave them as is? Any benefits to changing them? I emailed their customer support and got zero help.
Old 02-27-2014, 04:37 AM
flattusmaximus78's Avatar
Whats done to the car, you can close it if it makes you feel better.
Old 02-27-2014, 05:57 AM
jstrime's Avatar
I had a 2000 SS that hated any other spark plugs than the AC Delco Platinum from GM. Just my experience. Not trying to sway you different. Hope they work for you.
Old 02-27-2014, 09:37 AM
rjla67's Avatar
Just basic bolt-ons and a tune. What's the advantage of going down from .060 to .050?
Old 02-27-2014, 09:47 AM
mjs1012's Avatar
I usually gap those at .55 and have not had any issues.
Old 02-27-2014, 10:12 AM
Formally Simplɘ Jack
BoricuaHec01's Avatar
Leave them as is, already pre-gapped for your qualifications.
Old 02-27-2014, 11:10 AM
It's not mine! woo hoo!
demonspeed's Avatar
Iridiums aren't to be touched; however, GM specs .040 for iridium plugs in LSX motors.
Old 02-27-2014, 04:06 PM
rjla67's Avatar
Thanks man. I'm gonna gap em at .040 and run them to see how they do. I saw the TSB so I'll follow their recommendations.
Old 02-27-2014, 05:14 PM
BWZ_2k2Z28's Avatar
I was told the same thing by a mechanic. He said that iridium should come gapped to your specific application and not to do anything to them other then to measure the gap to make sure they are correct. I seen the general consensus around here is running .45-.55 so that's what I wanted to run. But I couldn't find any iridium plugs with a gap different then then .59 and I wanted iridium so I couldn't do it once and not worry about it again.
So what are your options with iridium plugs? Can you change the gap in them or not?
Old 02-27-2014, 05:53 PM
rjla67's Avatar
I ended up getting a new set. The ones I originally got was the NGK TR55IX #7164 that comes pre-gapped at .060. I checked the NGK website and the what they recommend for my Camaro is #7397 which are gapped at .040.
I also called WS6 and talked their tech finally who also recommended .040 and I just need to re-gap the ones I originally bought. I said screw that and got the correct ones and these will be shipped back for the tip on the iridiums are so thin it wouldn't take much to break them.
The new ones will be going in tomorrow so hope all goes well.
Old 02-27-2014, 05:57 PM
rjla67's Avatar
Also wanted to add demonspeed brought up the TSB with the new iridium plugs and GM now says .040 for gap contrary to the engine label that says .060.
Old 02-27-2014, 07:59 PM
BWZ_2k2Z28's Avatar
well this thread has sold me. I'm runnin the iridiums with a .06 gap and I swear I can hear spark knock when under load. I've had 3 different people in the car with me and I'm the only one that can hear it. I'm getting SH*TTY gas mileage too. As soon as I get a warm day I'm swapping plugs.
Old 02-27-2014, 08:39 PM
rjla67's Avatar
This was added to the WS6 website after I spoke to them today:
"Prior to 2005 GM used .055 GAP spark plugs on all LSx motors (this size). Starting in 2005, they switched to .040 GAP plugs to provide a better idle when things like cheap gas are encountered. Either a .060, or .040 GAP plug will work in any LSX motor with the smaller GAP being best for daily driven, mildly modded cars."
(http://www.ws6project.com/user_stor/...s-box-of-4--1/)
BTW, the local AutoZone/Advanced Auto carries the NGK #7397 FWIW.
Old 02-28-2014, 08:54 AM
demonspeed's Avatar
Kudos to rjla67 for providing some good specifics regarding the platinum vs. iridium transition
Just as an aside, GM replacement plug is ACDelco 41-110. These are the ones I went with when I did long tubes. I did not even check the gap before installing because I did not want to stress over screwing up the tip
Old 02-28-2014, 12:48 PM
BWZ_2k2Z28's Avatar
HAHA exact same here. $6 a plug? There was no way I was gonna even risk it.
Old 02-28-2014, 06:34 PM
rjla67's Avatar
Got them installed this morning. After a brief hiccup with the #6 cylinder not firing for the plug wire wasn't fully seated, the engine purrs like a kitten.
The plugs I took out were from the previous owner and still the original plugs. They were AC Delco (#41-931) and were gapped at .060 (some even wider then that).
So in summary if anyone is looking to put some iridiums make sure they are gapped at .040 with the part numbers in the above post and you will be fine.
Thanks everyone for their contribution.
Quick Reply: NGK TR55-IX Spark Plugs Gap
