Could you PLZZZ tell me what these motor mount torque specs are refering to?
Old 03-26-2014, 08:58 PM
Freefallin's Avatar
Engine Mount Stud-to-Engine Block - 37 lb ft
Engine Mount Through Bolts - 70 lb ft
Engine Mount Through Bolt Nuts - 59 lb ft
Engine Mount-to-Engine Block Bolts - 37 lb ft
All i wanted to know was the torque spec for the engine mounts for my ls1 GTO. Thought it was 1 nut that holds the mount to the engine, therefore one torque spec. A searched yielded the above and now im confused.
Could someone please explain what exactly are...
1. Engine Mount Stud-to-Engine Block (is this the bracket?)
2. Engine Mount Through Bolts (no clue what this one could be)
3. Engine Mount Through Bolt Nuts (?)
4. Engine Mount-to-Engine Block Bolts (?)
Thanks a lot in advance!
Old 03-28-2014, 09:20 AM
97FormulaWS-6's Avatar
Location: Land of the Mormon's although I'm not one of them
1) this is a stud that threads into the block and holds the upper bracket to the block
2) this is the long through bolt through the rubber/poly mount. This is the value to torque the bolt if your torque wrench is on the bolt head, and you're holding the nut still.
3) this is the nut on long through bolt through the rubber/poly mount. This is the value to torque the nut if your torque wrench is on the nut, and you're holding the bolt head still.
4) this is a bolt that threads into the block and holds the upper bracket to the block
Old 04-02-2014, 03:59 PM
Freefallin's Avatar
Beautiful! Thanks a mill buddy!
Quick Reply: Could you PLZZZ tell me what these motor mount torque specs are refering to?
