Ls1 seems no more powerfull then my lt1
Alright so I think my car has a clogged cat or maybe a bad o2 sensor as iv owned it maybe 3 weeks now and it's been the same but a ls1 should be more powerfull on the top end then a lt-1 and mine just seems the same
Iv had 3 lt-1 Camaros and 2 were stock except air intakes so it's puzzling me why the ls1 isn't a way better performer.
So just want some input... oh and I think it has a small vac leak as it idles from 800ish to 1100ish rpm surging... But hasn't stalled or anything close to stalling before.
Is the SES light on, or have you scanned it for DTC codes ?
Give the PCV system a look over for any cracked hoses, its a common vac leak on aging cars. I would also look in to a tune up... Spark plugs, wires, fuel filter, air filter, and oil if it hasn't been done in a while.
I agree with above the butt dyno can be deceiving but the LT1 is slightly under the LS1 power stock for stock.
If you do really do have a vacuum leak or 1 or more of many other possible issues, it will sap the life out of any engine.
Sounds like after a visual hose check you need to start off with a code check , see what shows up & go from there.
An LS engine feels a lot different than an LT1 IMO.
A few of my friends have LT1 4th gens with bolt on's. When I bought my 2000 Firehawk(lid & SLP y pipe) I thought the same thing as the OP. The LS engine's power seems to smoother and more linear than the LT1's.
It's deceiving the way it feels.
OP has the car had a tube up recently? Have you checked the STFT's and LTFT's to see if it might have a vacuum leak?
yup. I have both. the lt1 just seems to hit harder when you punch on it. other than that I don't think my LE1 LT1 car will beat my bolt on ls1.
But yea I bought a new fuel filter last week and I couldn't find it near the motor so im guessing it runs somewhere on the frame like the ole c20 trucks huh? I just haven't had time to jack the car up and look
Ok well I guess what I meant is exactly what a few of yall said... the lt-1's just seemed more torquey then ls1 is.
the reason why you don't seem to 'feel' much difference is because there may not 'be' much difference in hp between your stock or lightly modded LT1 vs. comparable LS1. There have been up to 15hp discussed differences in stock LS1's in Fbodies, maybe a little more. I've always heard 1 car runs harder than another. So seat of the pants won't tell you it is much faster until you line them up same conditions and race. I've owned both, my LT1 with cold air and exhaust could run with the stock LS1's when they came out, of course LS1 with mods is a different story!
Not sure what his LT1 is putting down, and not sure what his LS1 is putting down, so there really may not be much hp difference to 'feel'. So many people say "I put a pulley on..or an electrice water pump on... and I can feel the difference" yea okay, I really can't. But I'm not going to call them a liar. I've raced and beaten LS1's with my '97 Z28 intake / exhaust LT1. Same goes for my LS1 Trans Am, you win some and lose some. Or just line 2 brand new cars up and race them, I can guarantee you that 1 will be faster - EVERY TIME. Be confused.
Right well people need to understand that ls1 cars are more for top end power not off the line so much now if we line up the lt1 against the ls1 well most likely the lt1 might just get the ls1 off take off but after that that lt1 will be in some trouble couse top end is where the ls1 feels like a unstoppable monster
Secondly, what you said was already discussed as well.
