Tap stock radiator?
Tap stock radiator?
doing my steam ports and have a 4 AN kit for it, it needs a AN fitting to finish.
Has anyone tapped the stock radiator on an 98-02 car with an NPT fitting? Is there enough material to do so?
Where is everyone running their steamvent to for the AN kits?
Moderator
A "bulkhead" 2-piece fitting might do. Then again, a LT1
style radiator would give you several other ports and a
fatter core too. So maybe you fill one less port than the
usual swap.
usual swap.
