Wanna get my vert into the 12's 1/4 mile
Old 04-15-2014, 09:48 PM
goldcar's Avatar
Default Wanna get my vert into the 12's 1/4 mile
Alright so I have a VERT 98 Trans am ls1 A4, and it has 3.23 gears, Slp loudmouth 2 Cat back, and a true fiber ram air hood so basically stock lol.
Anyways im getting these mods pretty soon:
1. Slp lid
2. Lt Headers
3. Cutout installed on stock y pipe
4. M/T Drag slicks
And Im hoping I can squeeze in a bigger stall converter in the future which I know is worth about .4 to .6 but forget about this comment as it'd be awhile from now.
SO my question is if the 4 mods listed would get a Vert ls1 into the 12's as im 17 and a mid-high 12 sec car is enough to kill most cars id run into
Old 04-15-2014, 10:00 PM
Zmg00camaross's Avatar
You will need a convertor!
Old 04-15-2014, 10:03 PM
goldcar's Avatar
So just to break like 12.9'S id need a bigger stall?
Old 04-15-2014, 10:06 PM
Well if you get all the bolt ons. Stock convertor can do it. May be hard with stock gear. But A4 is not my area since I am a stick racer.
Old 04-15-2014, 10:14 PM
goldcar's Avatar
Ok well I do plan on taking a week off of driving my baby to install a stall then get the TQ management removed but who know's when that'd happen. Also im guessing it'd be best to install the new Headers and new stall at the same time, so might just do those 2 first.
Old 04-15-2014, 10:15 PM
goldcar's Avatar
Anyways thanks for the help Zmg00camaross
Old 04-15-2014, 10:35 PM
I would install the headers and a good y pipe. One of if not thee most important bolt on.
Old 04-15-2014, 10:37 PM
big hammer's Avatar
high stall and mickeys will be your best bet.
Old 04-15-2014, 10:44 PM
goldcar's Avatar
Ok I guess instead of the cut out ill get the y-pipe, headers, and stall. Already have the cat back, so then ill have a full exhaust with those mods.
Old 04-15-2014, 10:56 PM
ez2cdave's Avatar
Small Nitrous Kit . . . Cheapest way to run 12's . . . No other mods needed 125 HP-175HP kit ,
Old 04-16-2014, 01:11 AM
Krab's Avatar
In an auto, I'd say the "quickest" route would be getting a stall and some sticky tires along with some weight reduction. You already have 3.23's, so that's a plus, but your 'vert means you've got more weight than non-vert's, so weight reduction will definitely help. Definitely get a lid. That might get you there, if not pretty close to it.
Old 04-16-2014, 07:46 PM
goldcar's Avatar
Yea I have thought about putting a 100 shot on it... But to safely do it it'd be like $800 which for $800 I could make it almost just as fast in the 1/4 mile except all the time without any possible damage to my motor
Old 04-16-2014, 07:53 PM
goldcar's Avatar
Yes sir I plan on doing a minor weight reduction to it which would maybe get it down about 80-100lbs less but nothing to drastic as it's not a straight up drag car lol.
Old 04-16-2014, 08:07 PM
97camaro383's Avatar
Have you ran the car at the track yet in its stock form?
Old 04-17-2014, 02:09 PM
ez2cdave's Avatar
Yes, but the Nitrous kit would affect your fuel economy in everyday driving.
What does the car run now ?
I predicted needing to drop 1.5 sec or more off the ET . . . About 150 HP additional +/-.
As for damage, "leaning on" a stock motor will always incur the risk of possible damage.
Old 04-17-2014, 02:12 PM
ez2cdave's Avatar
2. Lt Headers
You might want to check THESE out . . . 1 3/4" available now . . . 1 7/8" by the end of the year !
https://ls1tech.com/forums/generatio...available.html
Old 04-22-2014, 09:59 AM
spy2520's Avatar
Stall alone might get it there.
Old 04-23-2014, 10:28 AM
Exeodus's Avatar
The stall can do it if you hook, but the bolt ons you listed will not be enough on their own.
Old 04-23-2014, 10:32 AM
thunderstruck507's Avatar
Tracks vary around the country, need to know what it runs now as you could be anywhere from 13.1 to 13.8 stock (or possibly faster or slower than that range).
But stall and good tires are your best bet by far.
Old 04-23-2014, 10:38 AM
ez2cdave's Avatar
Best "bang for the buck" in Stainless Steel headers & exhaust . . .
Quick Reply: Wanna get my vert into the 12's 1/4 mile
