WhAt bellow to use for 104 lid and 100mm maf
Old 04-16-2014, 12:21 PM
transamfreak01's Avatar
Default WhAt bellow to use for 104 lid and 100mm maf
I have a 100mm maf and 104mm lid. The two holes do not line up at all and there is about an inch to inch and a half difference. I also don't have much room to play with as the gap is very short inbetween the two. Need help!!! Thanks
Old 04-16-2014, 01:56 PM
01ssreda4's Avatar
My 100maf plugged in my 104 lid perfect. Can you snap a pic of what you have and how it is setup.
Old 04-16-2014, 02:29 PM
Really?! Mine is completely off. Idk if it's bc it's an iron block or what that's pulling it down. But it probably an inch away from eachother but the lid opening sits and inch higher than the maf opening
Old 04-16-2014, 02:46 PM
VandykeT/A's Avatar
Mine came from intake hoses.com. I think it was a 4" (22 or 30) degree bend. Just needed trimmed. If your maf is smaller than the lid use black tape to go around the maf until it fits snug.
Old 04-16-2014, 02:59 PM
Ok I'll have to try that. I'll probably order both just to see if one will work. I just didn't think it would line up so shitty
Old 04-16-2014, 05:47 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
Try cutting the ends at an angle. That should fix your problem. It tends to do that if you have a Ram Air lower airbox like the WS6 cars have.
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Quick Reply: WhAt bellow to use for 104 lid and 100mm maf
