modification help
modification help
i have a 2000 5.3 truck engine and I was planning on running a ls6 intake manifold, what all needs modified or replaced? will a ls1 water pump help clear the ls6 intake?
Desired performance level ?
What kind of vehicle ?
Manual or Automatic transmission ?
Intended uses of vehicle ?
Do you have to pass Emissions / Inspection ?
I would use the truck intake if you can clear it with the hood, longer runners, more torque, less compromised by space. If space/room is an issue and that is the reason for the change then yes go for it but you will need a few things. Like car style water pump, hardware, fuel rail, map sensor, possibly the steam line crossover, etc.
