my exhaust too small in diameter?
im gonna be running a LQ4 with 799 heads p&p milled .025, torquer v2 cam, ls6 intake, 3 7/8" longtube headers, with dual 2.5" exhaust ran into a dual 2.5" y pipe with 3" outlet into a dynomax vt single 3" inlet and single 3" outlet muffler, my question is, is the 3" gonna be too restrictive? im also gonna be running a 3" electric cutout after the y pipe. all input is greatly appreciated. reason why im running a single in/outlet muffler is this is going on a nissan 240sx and there isnt much room to work with. and i want it as quiet as possible til i open the cutouts.
I see no problems. Thats bigger than the Intermediate pipe I have on my soon to be 224/228 cammed ls1. I have a similar header/ypipe but then the factory ( believe 2 3/4" ) into the f-body style crossflow magnaflow muffler. before the cam it was Quiet at idle and controlled loud at WOT. I love that muffler choice.
unless you are pure race non street I say you are good. A bigger pipe tends t omean scrape from what I hear. But hey I'm no expert just a fellow forum user
Since you plan on running a cutout I'd run a Y-merger with a 3.5" exit on it and continue to run 3.5" pipe into a 3.5" cut-out. After the cut-out run a 3.5"-3" reducer and run 3"pipe the rest of the way on back through the 3" in/out muffler. The reason to go with the 3.5" pipe after the 2.5" dual pipes is to not bottle neck the flow, ant least when the cut-out is open.
FYI, dual 2.5" and a single 3.5" pipe have about the same amount of flow.
As far as you muffler choice I just go with a regular Dynomax Ultra Flo Welded muffler with running a cut-out, and I would go with the largest one you can fit without running into issues.
