redesigned Pacesetters fit well
11 Second Truck Club
My friend just installed pacesetter LT's & 3" ORP this weekend (new batch). The fitment was alot better than when I did mine with the old design. No steering knuckle removed, and no K-member grinding. The y-pipe doesn't bang either.
I can honestly say the y-pipe is 100% better than mine was when I did mine 3 months ago. The headers tuck in nicely, not close to the k-member.
Pacesetter is the way to go now for budget if you get the new ones.
Do you think I would be able to weld in 2 magnaflow high flow cats on the ORY? Would I have any clearence issues? If I could, where on the pipe would you suggest placing the cats? Thanks
That would be a tight squeeze welding cats in the 3" Y-pipe. I'm sure it could be done though, especially with Random Tech metallic cats.
It does appear that the new y-pipe hangs alittle lower than the old style. My friends car is lowered though, and there's enough clearance still.
