Best Starter Motor lsx
Old 05-15-2014, 07:04 AM
Mr Monaro's Avatar
Talking Best Starter Motor lsx
After some feedback engine 468 11.5 comp will factory ls1 starter be ok or go after market.
cheers
Old 05-15-2014, 07:22 AM
That's MISTER MODERATOR
Paul Bell's Avatar
This is an EXTERNAL engine question.
With that many inches, you should be considering an aftermarket starter.
Old 05-15-2014, 10:41 AM
redbird555's Avatar
MSD is a great option i wouldnt use a factory starter on that motor
Old 05-15-2014, 02:09 PM
Orange Juice's Avatar
I'm still using a stock starter without issue. I have an aftermarket one but it won't clear the headers.
Old 05-16-2014, 03:45 AM
Mr Monaro's Avatar
More feedback on brands of starters so l know best brands.
cheers
Old 05-16-2014, 03:47 AM
Mr Monaro's Avatar
sorry about wrong section on forum.
Old 05-16-2014, 07:12 AM
Paul Bell's Avatar
I have a Meziere TS119 on order.
Old 05-16-2014, 02:54 PM
Can't remember the make of mine, I bought off a friend because it wouldn't fit his headers.
Old 05-16-2014, 03:53 PM
fengstang's Avatar
Oem is always good
Old 05-16-2014, 07:13 PM
Paul Bell's Avatar
Originally Posted by fengstang
Oem is always good
Not always. Many original starters had the "shorter bracket on one side" starter. These brackets are prone to breakage then the remaining long bolt breaks the starter mounting boss on the block. You DON'T want that.
Old 05-16-2014, 09:14 PM
Super Hulk Smash
JakeFusion's Avatar
When did they make that change? My starter looks like the one on the left...
Old 05-16-2014, 09:53 PM
Paul Bell's Avatar
I don't know Jake. My T/A had it. You can be sure I won't use it when I put my car back together.
Old 05-16-2014, 10:03 PM
Paul Bell's Avatar
https://ls1tech.com/forums/15260102-post100.html
Old 05-16-2014, 10:21 PM
Super Hulk Smash
JakeFusion's Avatar
Yeah, I started searching to see...
Looks like RockAuto and Amazon have a new unit from Quality-Built for $88. Part number is 6492SN.
The other option is the LS3 starter and a new pigtail that splices into the harness. My harness looks like crap, so I might go with a truck or the Quality-Built. If I ever go with a Big 3 wiring upgrade, the LS3 starter would be ideal.
Old 05-17-2014, 04:54 AM
Mr Monaro's Avatar
Thanks for helpful input will go aftermarket.Keep ideas rolling.
cheers
joe
Old 05-18-2014, 08:25 AM
redbird555's Avatar
ls3 is a great stock option. just know that the big black ground wire on the side of the block needs to be relocated with it. since the solenoid plug hits it on install.
Old 05-19-2014, 04:57 PM
Super Hulk Smash
JakeFusion's Avatar
I decided to try the Quality-Built deal. Has the updated bracketry but old style electronics.
Old 05-19-2014, 11:48 PM
Mike Morris's Avatar
LS3 starter with new pigtail. It uses two long bolts. And its smaller and lighter than the original one.
Old 05-22-2014, 08:32 PM
Paul Bell's Avatar
This box was holding my screen door open when I got home today.
As I'm doing an engine build, I'm gonna hang the headers on the motor while on the stand to see if there's any fitment issues.
Strange though-this starter came with non-knurled bolts. They are nice 12 pt stainless but I know knurled bolts help the starter from moving around. I'm probably gonna uses knurled bolts.
Old 05-22-2014, 09:48 PM
LPE 403's Avatar
cheers
Stocker here on my little 460......works juuuuuuuust fine.
Quick Reply: Best Starter Motor lsx
