Corsa Catback
Corsa Catback
Finally got the hear the corsa at WOT since I installed it over the winter but had to baby the car due to the ford 8.8 install (put new gears in)
it doesn't sound too bad- we added a custom 3" Y-pipe into the mix since the factory Y-pipe doesn't clear the sphon chassis mount torque arm with a D/S loop...go figure
Picked up the infamous floor rattle with the 3" y-pipe under certain loads when taking off, Im sure a set of poly motor mounts should fix that...atleast I hope
It could be a tad louder at idle, but overall I guess I am pretty happy...headers and high flow cats next year should really wake the car up and make it that tad louder that I want it...
It is a tad quiet- it's almost like it doesn't have exhaust when you are in the car just idling at a light, but you start to hear it around 2000-2500 rpm or so.
One thing that is slightly annoying is that you can hear the setup shift when going over bumps- my exhaust guy seems to think that is because it is bolt together and not welded, I dunno though...I need to find a fix soon though
It is a different sound though for sure, it is more "tuned" than raw sounding
