Horrible Luck Must Read
My problems just keep getting worse as the days go by. Here is the short version. Swapped out my Macs for a set of Flowtech longtubes, Stock crank pulley for a ASP (I'll get back to that in a min), LSX intake for my LS6 intake, and swapped in a slightly larger cam. Had the car all dyno'd, made 7hp less then before on the SAME dyno, and the car stopped making power at 5900RPMS.
I have noticed for the past few days a slight noise under the hood like a belt squeak. Replace the belt today and it seemed to have cured the squeak, that is till I am on my way to work. Take the car up to around 5k in first and 2nd and let out, no biggie, do it all the time. BOOM! Pull the car over to the side of the road to find out, my belt has came off, but wait it gets better. So did my damn PULLEY!! WTF?!?!?! The pulley has been on the car for the past 3 months and not one problem till now. Here are some pics I took tonight. I am so fed up with this **** I am about to buy a ford.
BTW: The reason it is all chewed up is I guess I also ran over it in the process. I have also had the pulley installed for almost 4 months now too.
Wow, that IS horrible!! GL on your ride man.... and do yourself a favor.... Don't defile yourself w/ a Ford.... She may be sweet & tempting looking, but you'll never be able to look yourself in the mirror if you do it w/ her.
Yeah, you modified a car, made less power with it, then screwed up something and its the CARS fault!
I say, push it over a cliff and collect the insurance money. Then go buy yourself a nice safe honda civic or v6 mustang with a K&N airfilter, neon plug wires, and a real big tip.
LS1Tech Co-Founder
I have seen that happen when folks did not hit the full torque spec for the pulley or they reused the old bolt... But what is the case for you?
Sorry to see that happen, that must have been a pain to deal with.
that belt squeaking you refered to was the pully coming off the crank ... i know i had it for a few days ... thought it was my PS pump or something but I looked down noticed the ASP was coming off the crank... tightened it backup no more squeak... for all that read this... ASSUME the squeak is your pulley coming off first... check the bolt for tightness !
Hey, it could have been worse. A buddy of mine had his come off while at the track. He was at about the 1/8 mile mark when his came off, but he didn't manage to run over his. His hit the ground, bounced up and cracked his oil pan. After that, the pulley was spinning so fast it jumped off the track and was never seen again.
So with that said, things could have been worse.
or it could have been like mine. Im the guy from texas whose pulley flew off. I was right in the middle of a race with a gsxr 1000 when at about 130 or so the pulley decides to chunk itself off. Took out my oil pan, driveshaft, and left rear Nitto in the process before it bounced out the back. When i checked the bolt was broken off inside the crank Called up Lee @ASP and he has volunteered to replace it (the pulley) thought im not really sure i want to reinstall one
LS1TECH Sponsor
Originally Posted by foff667
well one way or the other if the bolt broke off or backed out it really sounds like user error in most cases.
Are you just retarded? How do you get a "USER ERROR"? This aint a computer where when they mess up its mostly because of a "user virus," This is a part that i had installed (i didnt do it myself) correctly by the dealership. What did i punch the gas at the wrong time or could it have possibly been i am making too much power and its my fault that the materials i paid good money for failed
Some people have nothing better to do that add useless comments to an otherwise great thread
LS1TECH Sponsor
LS1TECH Sponsor
Originally Posted by HC02SS
It was tightened down correctly it just broke. Talked to LEE at ASP also and they are going to replace the pulley. BTW: new crank pulley also.
LS1TECH Sponsor
Originally Posted by 2xLS1
Since you did not install the pulley yourself, you can only assume it was installed correctly. I know people who work at dealerships that use shortcuts all the time rather than following proper install procedures mostly to save them some time.
