which catalytic conv do you use and why
I searched already. I am going to have my exhaust redone at a local shop. They will not touch it unless i have cats and they said i will not pass emissions in Indiana without them.
Anyhow I have Pacesetter ory. I am going to have them add a Flowmaster merge 3" with 4" outlet and Hawks 4" exhaust.
I want good flowing cats obviously and need them to fit properly. Driver side worries me with that flatter section of piping.
I need advice.
Rear o2 have been deleted already
I need advice.
I'd go with the Magnaflow #59929 they last longer, and flow better than the ceramic #54950.
http://www.summitracing.com/parts/mpe-59929/overview/
http://www.summitracing.com/parts/mpe-54959/overview/
As far as the installation location, the passenger side is easy since you have a lot of room, but with the drivers side you can mount it further back before the Y-pipe merger like how TSP does with their catted Y-pipe.
http://www.speedengineeringlsx.com/s...Pipe%20New.jpg
LS1Tech Premium Sponsor
Like 99Bluz28 said, I would mount them in the same location that we do on ours for the best clearance. If you have to pass a sniffer test, use the Kooks "green cats". Otherwise if it's just a visual inspection use the Magnaflow style cats. Though, since the Magnaflow cats are moved much further downstream and flow so much they will still trip an O2 code so the rear O2's will still need to be turned off.
Lonnie
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Lonnie
Lonnie
The Kooks "green cats" should. I still feel the Magnaflows flow too much. I couldn't give you a definite answer on that one.
Lonnie
Lonnie
__________________
Thanks for the input. Just trying to understand their purpose if they don't pass the sniffer. Might as well just go with "fake" cats if all a guy needs is a visual inspection. My only reason for wanting cats is to cut down on the raw fuel smell but if they don't pass a sniffer then I don't know that they'd cut down on the fumes either.
That's exactly why people use them. To cut down on the raw fuel smell and to pass "visual" inspection.
Lonnie
__________________
also up yours EPA!
