Do i need a retune??
Already have a Frost Mail Order tune, for Basic bolt on's LS6 Intake and LS6 Cam. Hence after only 400 miles, I'm doing another rebuild, everything will be the same except for going .025 over bore and the new addition of a set of 243 heads. So send off and get a retune or would the one I be just fine?
could someone explain why he would need a new tune? i wouldn't think heads only would lean him out that much from his current A/F ratio. & doesnt the computer learn & adjust for that small of a change? different story if he only had a stock tune.
the computer can learn part throttle air fuel changes but if it adds fuel to part throttle because it's leaner it will add that much to WOT just to be safe
without tuning for major component changes you are either sacrificing part of the gain from the parts or possibly even making less power than before if the swing is big enough
243 heads have more flow and more compression, the car will most likely run great with them but will also most likely be leaving power on the table...the only way to know is to scan the car to view fuel trims and check for spark retard
At full throttle though it doesn't learn squat, so you'd need a re-tune if you wanted to get on it at all...otherwise you'd burn a piston real quick.
