Thirdgen lsx swap A/C refrigerant capacity?
Old 06-15-2014, 09:15 PM
Mgg4591's Avatar
Default Thirdgen lsx swap A/C refrigerant capacity?
So I finally got my ac working in my thirdgen with an LM7 swap. The ac works pretty well, but i feel it should be colder. I think it may be overcharged. I used the a/c machine at my job to vacuum, inject the oil, and charge the ac. I pumped in 2.5lbs, which is the capacity for a thirdgen. Im using a thirdgen condenser, evaporator, and accumulator, and a 4th gen compressor and hawks swap ac hoses.
Should i recharge the system with the 4th gen ac refrigerant capacity, being I'm using a 4th gen compressor? Not sure what the charge should be around using a mix of third and 4th gen parts. Any help would be great.
Old 06-15-2014, 10:47 PM
That's MISTER MODERATOR
Paul Bell's Avatar
You'll probably get good answers in the conversions section. This here's kinda for engine related stuff and as you did do a conversion....
https://ls1tech.com/forums/conversions-hybrids-28/
Old 06-16-2014, 11:42 PM
Super Hulk Smash
JakeFusion's Avatar
LS1 is 1.5lbs I believe, so you're probably overcharged.
Quick Reply: Thirdgen lsx swap A/C refrigerant capacity?
