Voltage Drop at WOT
Old 06-25-2014, 12:58 PM
rjla67's Avatar
Default Voltage Drop at WOT
So I have a issue that I cannot seem to correct where at WOT I am seeing a voltage drop above 4000RPMs which will cause the lights to dim and just before red line, the check gauges light will come on. It will return to normal if the accelerator is released. Cruising around the problem will not surface at all. So here's what's been done so far:
  • Brand new GM alternator (lifetime warranty)
  • New power steering pump
  • 1yr old GM water pump
  • New GM belt tensioner
  • New GM belt & new Gatorback belt
I have another alternator coming to swap out to see if that is the problem for I've never seen this issue before so that is what I *hope* the issue is. I'll also be replacing the battery just to make sure but I can't see what that would cause the issue. Only other thing I was thinking was belt slippage but other then the crank, every pulley is clean and brand new including the belt so that kinda rules that out.
The car is slightly modded with the usual bolt-ons and was tuned and I don't have much in the way of electronics to draw lots of power.
Is there anything else I should be looking at while I got the car up and replacing the alternator like grounds or such anyone can think of?
Old 06-25-2014, 04:24 PM
b4cz2896's Avatar
I had the same issue with multiple "re manufactured" alternators. I finally fixed it by buying a used one from a junk yard.
Old 06-25-2014, 04:40 PM
rjla67's Avatar
Wow, never would of guessed a junkyard one would be better then one remaned. I've seen lots of threads here on the subject but not one really solves the issue that I can see.
Belt slippage is the most common response but I know that it isn't the issue. It's gotta be the brush springs since it only happens at high rpm's.
Old 06-25-2014, 05:12 PM
studderin's Avatar
UD balancer?
Old 06-26-2014, 08:04 AM
gagliano7's Avatar
My junkyard gave me a lifetime guarantee on my truck 130 amp alternator . Alternator cost $80 from junkyard.
Old 06-26-2014, 02:52 PM
99Bluz28's Avatar
Originally Posted by studderin
UD balancer?
OD alternator pulley would be more likely to cause higher rpm alternator issues(over revving), but his issue sounds like it's just a bad(new) alternator.
Old 06-26-2014, 11:17 PM
rjla67's Avatar
New alt going in tomorrow so hopefully that is what the issue is.
I also replaced the idler pulley today while I got it apart for it looked scorched and it didn't freely rotate so the bearing must be going out and is binding.
Strangely when I want to the parts store the one listed for my year was completely wrong (and $58). The inside of the pulley facing outwards was straight whereas it needs to be at an angle going down for the dust shield to sit correctly. Had to lookup one for a 2000 Corvette and it works perfectly (and only $20).
Old 06-27-2014, 06:23 AM
silversrtman's Avatar
I had a similar problem a couple years back. I went through 3 alternators and the buick tensioner pulley trying to find the problem. Turns out a katech tensioner was the answer. Idk if this is your problem but couldnt hurt to try, plus the katech piece is really nice looking and its about the same price as an oem tensioner. Good luck.
Old 06-27-2014, 03:09 PM
rjla67's Avatar
Swapped out the alternator and it performs as it should so it must of been a bad rebuild.
Just a precaution I also replaced:
Battery
Battery terminals
Idler pulley
Tensioner pulley
Belt
PS pump
Tightened up all the grounds
New spark plug wires
Removed the exciter wire from the plastic wrap so it wasn't as tight and has a little more slack
Might of gone a little overboard but didn't want to take a chance.
Old 06-27-2014, 09:48 PM
rjla67's Avatar
Well took it out again to test and it's doing it again. This time, the voltage won't come back up so I am at a total loss...
Old 06-28-2014, 02:25 PM
bmax's Avatar
Maybe take a peek at this.
https://ls1tech.com/forums/generatio...-failures.html
Good luck
Old 06-28-2014, 09:10 PM
rjla67's Avatar
Well, went through the entire system again. The brand new GM alt burned out after only one WOT test run and was not charging the battery. Everything else checked good so as it turns out threw in a rebuilt alt that has better internals and so far she's holding steady as it should.
Old 06-28-2014, 09:55 PM
Majestic9C1's Avatar
stick a 145A truck alternator on...
why GM decided to use a 102A alternator on these cars is mind boggling
Old 06-28-2014, 11:25 PM
rjla67's Avatar
I agree. Even with just basic bolt-ons and the stock stereo, these alts GM uses just can't handle the load and crap out at high rpm's. Driving around normally the problem never surfaces but who does that?
If it happens again I'll just have it locally rebuilt with high-output internals and be done with it.
Old 07-02-2014, 01:21 PM
BubaGumpShrimp's Avatar
Just a quick note, make sure your power steering lines are not leaking. A lot of people have issues with leaking pumps/lines and the alt is right under it.. I had this issue along with 3 alt swaps till the high pressure line fully showed its leak and drained the tank right into the alt taking it out...
Old 07-02-2014, 01:40 PM
rjla67's Avatar
Already replaced that so it's good there. It was leaking a little so I replaced it to rule that out.
Old 07-03-2014, 03:23 PM
Footlead's Avatar
Default Do This
Good luck
Put one off a truck or suburban, yukon on it. read the link above. I did and it works great. I had my original rebuilt and the same thing. lights dim on WOT The alternator is a bad design. Youtube videos confirm it.
Old 12-20-2014, 06:52 PM
NVUSZ28's Avatar
I hope you have fixed the issue, but check this out, it fixed my voltage drop at WOT.
http://www.calspeedperformance.com/p...cei-102130.htm
Quick Reply: Voltage Drop at WOT
