Any disadvantages to 1 7/8 long tubes?
Looking at a full exhaust in the near future. I don't have the power to fully use 1 7/8 right now but I will in the future. Any reason not to go ahead with them?
Truthfully, clearance really shouldn't be an issue compared to 1-3/4", that's only 1/16" less clearance all around each of the tubes. So if clearance an issue between a companies 1-3/4" and 1-7/8" headers it's because differences in the bends angles, not tube diameter. The only area that I can see possibly having any possible clearance issues is around the collectors.
IMO, go with the best 1-7/8"you can afford. You'll be less likely to have clearance issues when the degree of the bends aren't choose by cost first; flow, an fitment last.
yes pretty much lol 1-7/8" will always outperform 1-3/4" however unless yours are bad I wouldn't necessarily change unless your after all the hp you can find on a 346 it would be worth 5-10 but more on a larger build.
The Scammer Hammer
Exactly. I went with duals myself bc tips on a Camaro look flat out stupid to me. However, after doing TSP Stainless 1 7/8" headers and their 3" duals, I knew I was absolutely and completely done, no matter what other mods I did to the car.
well, this made my decision Ez! 17/8 TSP's it is!!!
Def not true. the only people who write that are ones that havent tried them. I witnessed it when I swapped mine to 1-7/8 arh's. A stock motor will gain hp every time
