How much hp gain from LS6 to FAST intake?
Old 07-22-2014, 11:25 AM
somethingclever's Avatar
Default How much hp gain from LS6 to FAST intake?
Car is a 2005 CTS-V.
I am wondering if there are any gains (mid-range and peak) in swapping the intake and throttle body out for something else.
346" LS6
11:1 comp
ported 243's (no flow sheets but professionally done)
Custom comp cam 3633R/3475R which is 228/238; .600/.613; 112+3
Kooks 1 3/4 LT's, off road midpipe, cutouts
K&N FIPK
stock TB
stock ls6 intake
I am getting a retune on the car and thought before I do that maybe there could be considerable gains on the intake side. Since the cam is not common, it may be difficult to say if the engine will like the larger intake tract or not.
Old 07-22-2014, 11:33 AM
HCI2000SS's Avatar
Probably around 15 hp
Old 07-22-2014, 12:05 PM
7GRANDGERNADE's Avatar
I've seen gains from 17-22 when ported
Old 07-22-2014, 12:53 PM
05RavenV's Avatar
^ this
Old 07-22-2014, 01:25 PM
BandDirector Blk98ZM6's Avatar
I've got a stock crate LS6 longblock swapped into my '98 Z28. I put down 385.9 RWHP with an LS6 intake and stock ported TB (as well as the usual bolt-ons). I swapped over to the FAST 92mm and Nick Williams 92mm TB and then got back on the dyno and put down 400.1 RWHP. This has all been within the past month too. My FAST 92 was NOT ported, just as it came out of the box, and I picked up roughly 15 RWHP with it.
Old 07-22-2014, 01:34 PM
are these peak pickup's or also mid-range?
The V is a portly car at 4000lbs with driver....mid-range is good...also the car is a DD...and rarely is at hp peak.
Thanks for the feedback so far.
Old 07-22-2014, 02:55 PM
redbird555's Avatar
The FAST will begin to pul away from the ls6 around 3500 rpm. The torque in the midrange will improve a lot which is more of what you'll "feel" driving around tq gains are usually anywhere from 15-25 depending on the setup. The hp there maybe roughly 5-10 more but will keep pulling away as rpms climb. It's def worth while if you have the money and I'd say your car would greatly benefit from one.
Old 07-22-2014, 03:09 PM
Chris25's Avatar
Those are nice numbers really making me want to ditch my LS6 intake for a FAST 92.
Old 07-22-2014, 05:10 PM
svede1212's Avatar
You have almost the same setup I had and a FAST 102/NW 102 netted me 18 RWHP
I had 228/232 .612/.600 111
CNC'd 243s
LTs
42# greentops
I also optimized my exhaust system adjusting my mid-pipe (collector) length and switching to Borlas and gained 30+ ft/lb RWTQ at 2,000 RPM
Old 07-23-2014, 12:49 PM
those are some pretty respectable gains...especially in the mid-range where I need it the most.
I just wish those pieces of phenolic and dbw TB's weren't such big money! After that I would end up needed more injector too. doh!
Old 07-23-2014, 03:33 PM
I'm also on shorty headers and still have the stock cats. I'm very pleased with my numbers after the FAST 92. I was on a quest to hit 400 RWHP without touching the internals of my LS6 and the FAST 92 got me where I was hoping it would!
Old 07-23-2014, 03:56 PM
svede1212's Avatar
Here ya go. An A>B comparison
Old 07-23-2014, 04:29 PM
Goosecaddy05's Avatar
you can get played easily from people trying to sell you on the fast intakes... realisticly you wont gain more than about 5-7rwhp even with a ported one... the flow of a ported fast 92 is only about 7-10 cfm higher than a stock ls6 manifold... totally not worth it for the money in my opinion... and i have a ported fast 92 done from Vengeance racing
Old 07-23-2014, 05:00 PM
HCI2000SS's Avatar
If this was a max effort build, or you just had money to burn I'd say sure...go for it. Otherwise imo they really aren't worth it
Old 07-23-2014, 05:14 PM
svede1212's Avatar
That's amusing seeing you posted this right after I put up a composite graph of the same car on the same dyno disputing your statement. My comparison is from my LS6 manifold that had the neck ported out for a 80mm TB too. It's entirely likely you didn't see results because you have a bottleneck somewhere else holding it back.
Old 07-23-2014, 05:40 PM
BlueBird346's Avatar
I think they're worth it. Especially if you can find one used. I haven't dynoed mine to see what kind of gains it gave me, but everyone who has has convinced me.
Old 07-23-2014, 05:42 PM
Always2Slow's Avatar
Did he cut the pulls early on those setups or did you start running into valve float?
Old 07-23-2014, 05:44 PM
Sounds like you have crappy heads. On a bone stock motor you will pick up everywhere. The more mods you have the more your going to pick up. A ported Fast is worth alot more than 7-10 cfm by the way and its where you actually need the CFM as well.
Old 07-23-2014, 07:33 PM
01MAROONz2890's Avatar
Damn dude pass whatever you're smoking....
First off an ls6 intake in stock form flows 247 cfm give or take. A FAST 92 flows 265 out of the box unported and a FAST 102 flows 272. Both gain quite a bit when ported but even 5-10 cfm will show a measurable dyno gain
LS6 Stock Intake
.100 72.2
.200 141.7
.300 204.4
.400 227.4
.500 247.7
.550 256.0
.600 260.5
.650 269.5
Fast 92 - Stock
.100 71.4
.200 144.7
.300 205.9
.400 235.7
.500 259.0
.550 270.8
.600 272.6
.650 276.2
Fast 102 - Stock
.100 74.4
.200 150.7
.300 211.9
.400 241.7
.500 265.6
.550 271.7
.600 274.0
.650 278.4
Old 07-23-2014, 08:00 PM
Rise of the Phoenix's Avatar
OP, guess you need to ask yourself if the gains are going to be worth the cost. There are gains to be had, that's been proven, but only you can say if it's going to be worth it in the end.
Quick Reply: How much hp gain from LS6 to FAST intake?
