NEED HELP noise comming from front of motor external possible pulley? water pump?
Old 07-24-2014, 04:17 PM
TxOutlawZ28's Avatar
Default NEED HELP noise comming from front of motor external possible pulley? water pump?
My car is running decent but I started to noticed a still ticking noise I changed out the belts and spun all the pulleys they all rotated fine. Im at a loss because while it is not over heating im afraid it may be the water pump. So I haven't driven it since but I hate letting it sit and dont like to pay mechanics for a job I can possibly do.
Is there a sure fire way of checking this without removed? Maybe the water pump pulley is loose and I didnt feel it. Im new to LS motors used to SBC so any help or advice would help thanks in advance
Old 07-24-2014, 08:41 PM
S10xGN's Avatar
Did you run the engine with the belt off? That will tell you a lot...
Old 07-26-2014, 03:31 PM
Default running with motor with belt off, what will it tell me?
no I have not tried that, what will it tell me?
or should I look for?
like wobble in a pulley or??
Im lost on that ive never tried it
Thank You
Old 07-26-2014, 03:56 PM
My buddy took a look and thinks it is the power steering pump its always leaked and he said it is a common problem on the ls1 for them to go out.
Old 07-26-2014, 09:08 PM
S10xGN's Avatar
Thank You
It'll isolate the problem to either the belt (FEAD) system or the engine itself. Once you get that info, there's a little more to do to find the culprit...
Quick Reply: NEED HELP noise comming from front of motor external possible pulley? water pump?
