LS valve cover
LS valve cover
New to the LS and stuffing big turbos on them seems to easy. I have what may seem to most to be a dumb question. The tubes that come off the valve covers to the intake I am assuming they are essentially crankcase reliefs? If so what is a simple but effective way to disconnect from the intake? I am pretty sure that the passenger side tube where it connects just behind the throttle body is blowing oil when it goes under boost. Any and all suggestions are greatly appreciated.
I have all 3 ports on my vale covers plumbed in to a vented catch can. Works well drain about 6-oz every oil change. I also removed the pipe in the throttle body and taped threads for a plug.
You can also do a search for "mighty mouse catch can" in the FI section if you want to run a PCV, he makes a good sealed can.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
It's the PCV system. From what I understand, it helps with blow-by and something else that I can't remember. Apparantly it's complicated and important, but on LS1's, those lines tend to suck in oil to the intake via it's vacuum. Do as suggested above or google search the mighty mouse.
