4150 Throttle body and Vic JR. intake on 5.3??
Old 07-28-2014, 11:44 AM
stock4.8's Avatar
Default 4150 Throttle body and Vic JR. intake on 5.3??
I am running a stock bottom end 5.3 and wanted to go to a Edelbrock Victor jr. intake with a 4150 4 barrel throttle body. My questions are: Is that too much intake for a 5.3? How will it react to a nitrous plate? How is the driveablity with an intake set up like this? What kind of gains can I expect over a LS6 intake?
Also, How do Edelbrock 4150 throttle bodies perform and drive? They seem very reasonably priced.
Old 07-28-2014, 12:33 PM
Rise of the Phoenix's Avatar
Take a look at this thread. A Victor Jr. with a 4150 style TB would be killer on a 5.3, just like this guy did. He does not have a cam (he has stock cam) and look at the power it made. If he would throw in a custom grind cam, it would be even more ridiculous. As far as the 4150 TB goes, a lot of people like the FAST, Accel, or Scorpion 4150 TB's. The good thing about the Scorpion TB is that it's a low profile one, so clearance is much better.
https://ls1tech.com/forums/dynamomet...8-headers.html
Old 07-28-2014, 02:28 PM
stock4.8's Avatar
Awesome! I was looking for a thread like that. I couldn't really find anything.
I don't have to really worry about clearance. This will be going in GTA. I wanted to know if the Edelbrock throttle body was good as far as daily driving and driveablity. Or if the Accufab is worth the extra money.
Old 07-28-2014, 03:30 PM
Can't really say, as I've not heard really anything about that TB. I'm sure it's fine, but if you look at the classified section on here, you'll likely get a good deal on a 4150 TB. One thing you'll want to do is make sure to get a custom cam for the setup. The off the shelf cams out there for LSx's are designed for a composite style intake like the LS6 and FAST intakes. Because the Victor Jr. is a single plane intake, you'll need a custom cam with the right valve events for that style intake and TB. What heads are you going to run on it?
Old 07-28-2014, 05:00 PM
stock4.8's Avatar
Ok cool. I will be running 241 heads, I going to have them milled so I can bump the compression up a little bit. I was just trying to get a few reviews on the Edelbrock before I went with it.
Old 07-28-2014, 10:25 PM
Fry_'s Avatar
the_merv has the Edelbrock tb on his LSX swapped Monte Carlo SS, I don't know of anyone else using one.
Old 07-29-2014, 08:29 AM
How much is the Edelbrock TB? I know the 4150 style TB's are pretty pricey.
Old 07-29-2014, 11:57 AM
stock4.8's Avatar
i believe the Edelbrock is around $475
Old 07-29-2014, 12:29 PM
I would take a look at the Accel throttle body.
http://www.summitracing.com/search/p...hrottle-bodies
Old 08-27-2014, 03:41 PM
stock4.8's Avatar
Hey guys. What kind of power can I expect out of a cammed 5.3 with a vic jr intake set up?
Old 08-28-2014, 01:14 PM
Way to vague in order for anyone to answer that question. Way too many variables. How about you tell us more about the combo.
Old 08-28-2014, 05:32 PM
studderin's Avatar
check this one out too.
https://ls1tech.com/forums/dynamomet...out-gians.html
And get a fast/accufab 4150, its worth it. there are VERY nice
Old 08-29-2014, 07:49 AM
^^^ This man speaks the truth.
Quick Reply: 4150 Throttle body and Vic JR. intake on 5.3??
