Intake Hoses Part Number Needed
I need the part number for the hose I need to connect my SLP lid to my stock size TB. I have gone into all the part stores around here and none have the right size hose/coupler I need. I want this hose to go over the neck of the lid and over the TB. Thanks in advance.
I measured the TB and from edge to edge, it's 4". My air lid opening is just a hair short of 4" from edge to edge. I guess that means the 3.5" diameter one would not fit over the TB and lid neck, so it seems like the 4" diameter one is what I need. I have searched and searched this and some people say they've used the 4" diameter one and others say it's too large and you really have to clamp it down, which is why they used the 3" diameter one. Intakehoses.com has all different sizes, so that's where I"m going to order from. Anyone else know, or even better yet, have some installed pictures of what size they used?
The Scammer Hammer
92mm TB I take it... You need a 4" ID hose, end of story. Trust me
Home Depot Crap won't work bc it's sized for PVC, so add roughly 3/8" of an inch to it for wall thickness.
Ebay is your friend here. you'd need around an 8" length though, and I couldn't find it. I went 3 ply, as 5 is just too thick. I used 2 4" length, with a 4" piece of polished aluminum in the middle.
Search "102mm silicone coupler hose" and pick your poison.
Siliconeintakes.com or whatever is expensive last I checked.
That's MISTER MODERATOR
This will do what you want, order by the inch. I have some of the four inch (100mm) stuff and it fits my 92mm TB quite nicely.
Two ply black: http://www.siliconehose.com/4-000-id...e-gloss-black/
Four ply black, red or blue: http://www.siliconehose.com/4-000-id...j20-compliant/
Thanks Dave. I didn't realize the actual TB housing is the sams size. Since that's the case, sounds like the 4" diameter is what I need. Thank you for the help. I'm going to order it off the link Paul posted. Cheaper than intakehoses.com, and being 2 or 3 ply, it will be easier to bend if I need too bdcause it's not exactly a straight line from lid neck to TB.
I believe the angle you need is 22* for the correct alignment between the two ends (check to verify) . What you could do is get a 22* 4" diameter aluminum tube and use some 4" diameter straight silicone hose on the ends.
http://www.summitracing.com/parts/spe-9729/overview/
Curious the shipping charge, I started the purchase process at intakehoses.com. $12 to my area but I saw this curious disclaimer:
If UPS has to correct the address, you may be charged their "Address Correction Fee"
Which I consider pretty funny-UPS does NOT have a "address correction fee"
Well Paul, the link you posted had exactly what I needed and I could order the length I needed (6"). When I went to place the order, it was just as much to ship as it was for the actual piece. Intakehoses.com was much cheaper on the shipping. Shipping charges kill me. Hell, I've shipped heavy *** **** that didn't cost that much.
