Manifolds vs. Shorties
Old 08-10-2014, 11:58 AM
.boB's Avatar
Default Manifolds vs. Shorties
What's the power difference at the top end between stock LS6 cast iron manifolds and a decent set shortie headers?
Old 08-10-2014, 12:58 PM
NW-99SS's Avatar
From what I've read, literally nothing. Save the money for a better mod or Long-tubes.
Old 08-10-2014, 01:00 PM
WS6wanted's Avatar
Im not sure what the numbers are but if your looking for power, save your money for longtubes, y pipe and a tune. Shorties blooooooow
Old 08-10-2014, 01:13 PM
ULTIMATEORANGESS's Avatar
Smile
is there a reason why youre considering either of those manifolds?
Old 08-10-2014, 03:36 PM
.boB's Avatar
They're for a miata based car - very tight quarters. I can get corvette manifolds for <$100, shorties for $500, or long tubes for $1100.
Old 08-10-2014, 04:27 PM
NW-99SS's Avatar
2 options:
1. Pony up the extra cash or the LTs.
2. Save $400, get the Vette manifolds and use the cash for other mods.
Basically, shorties are all but worthless on LS engines - generally speaking.
Old 08-10-2014, 06:15 PM
Smile
I CHOOSE LTs for 1100.
Old 08-10-2014, 06:20 PM
madmike9396's Avatar
id do corvette manifolds unless its a max effort build. for 1100 you aren't gonna gain much hp.
that 1100 can be better used else where
Old 08-10-2014, 07:47 PM
.boB's Avatar
Originally Posted by NW-99SS
2 options:
Any particular 'vette manifold better than another?
It's not a max effort build. Then engine is actually fairly mild. I agree, $1100 can make more improvements in other areas - like better brakes or suspension.
Old 08-11-2014, 03:06 AM
if im not wrong I believe some factory manifolds do flow better than the others but im not sure which vehicle they came on. I want to say the vette.
I would do some searching on that
Old 08-11-2014, 07:26 AM
Blackpanther99's Avatar
^The newer the manifolds the better they flow is what most claim.
I wouldnt buy shorties at all.
Old 08-11-2014, 09:59 AM
FirstGen F-Body's Avatar
i would also go with LTs, but heres a test of vett manifolds vs 1 5/8 vs 1 3/4 LT vs 1 7/8 LThttp://www.carcraft.com/techarticles...t/viewall.html
Old 08-11-2014, 01:51 PM
NW-99SS's Avatar
Not 100% sure which Vette manifolds would flow better. I assume anything from an LS1-LS9 would bolt up?
Old 08-11-2014, 03:30 PM
all LS's use the same Cometic gaskets
http://www.summitracing.com/parts/cg...et?prefilter=1
Old 08-11-2014, 07:22 PM
Smile
i still vote LTs.
Old 08-11-2014, 10:59 PM
99Bluz28's Avatar
IMO, unless there's some really good flowing/fitting LT headers for a ls1 conversion Miata I'd just get the corvette exhaust manifolds, You can always get LT headers later. Keep in mind that if you plan to put a performance cam in it give it a 4* to 8*(@.05") I/E duration split.
Quick Reply: Manifolds vs. Shorties
