ls1 intake info
ls1 intake info
new member first post, i'm putting a 5.3 into a 62 belair wagon and i'm putting an ls1 intake on it, it has two fuel lines on what looks like a regulator i thinks it's off a camaro, i assume ones a 5/16 return and the other is 3/8 inlet, would someone let me know if thats right and do you plug the evap line or where do you run it to, thanks
That's a corvette LS1 fuel rail and a pulse damper on it (no return outlet on Camaro rail). The smaller outlet on the fuel rail is the fuel return. it goes back to corvette fuel filter/regulator.
Vette fuel filter/regulator:
http://www.improvedracing.com/images...39926_1_lg.jpg
so can i cap the evap line, and if i run the return line to the corvette filter regulator i won't need a return line to the tank right, is the 5/16 line out of my tank adequate enough or do i need to put in a 3/8
