Remove air dam to mount tranny cooler, any negative affect?
Having the Fast Toy ram air kit, I had to remove the black plastic air dam in order to mount the tranny cooler. Is there any negative affect in the plastic piece not being there? Also, is the FTRA kit still functional? I also have the windshield washer resevoir removed, so in my opinion from the looks of it, there is plenty of air moving across the radiator, but I could be wrong. Thanks. Here is a few pics:
Well I really cant monitor the temps. because the temp guage in the dash is just a 3 stage guage or however you want to put it. (cold, normal, hot) So I dont know if the temps. fluctuate. I figured since the washer fluid resevoir was out too, it may help.
Just to clarify, Im referring to the black flimsy plactic piece that was once in front of the FTRA kit, not the fairly thick on that goes all the way across the bottom of the car. Im not worried about the handling because the car only sees 1/4 track use and occasional street cruising.
Originally Posted by BlackBeaSSt
I guess thats what you call it...its the flimsy black plastic piece that went in front of the FTRA I believe. It sits in there at an angle. I believe it also snaps into the radiator on the sides. Thats the piece Im referring to.
