Should I put foam strip slp lid with k and n filter?
I got k and n and installed it into the stock air lid in my 02 TA with the supplied foam strip.
I have an SLP lid coming should be here any day now.
Did you guys use the k and n strip with your slp lid? I am not sure can get it out now of the stock lid or maybe will have to go buy some more weatherstripping at home depot or something ?
So who has used this stripping in the slp lid or is it necessary.
I can't say for sure if that was due to the K&N being over oiled or it not filtering well as I have no idea how or if the previous owner cleaned/oiled it. However, it was enough for me to throw it out and use a paper filter instead.
Also after I bought my SLP lid I noticed that the K&N didn't fit well under it for some reason even though it fit fine under the stock assembly. It was a little too big under the SLP one.
Just my experience with K&N, take it for what it's worth.
The Scammer Hammer
Run the K&N. It's a great filter. I myself put 1/4" weatherstripping all the way around just for a bit of a better seal. The seal on the K&N itself is a bit thinner.
Whoever says the power difference is the same between thick pleated paper and high flow cotton gauze... I want some of what you've been smoking.
Ok the k and n weather strip came off the stock airbox without tearing and put it on the slp lid. The slp lid also did come with some stripping to put on the back side stating in the instructjons some vague thing about using it for some filters not mentioning any specific names. I think the thing with the k and n is its a bit too small. Should be bit larger for better fit and maybe its rubber surround could also be thicker as well.
I bought some oil type BMC filters and have them in my Porsche 911 turbo, my SL55 and my son's 350z. They are always great fitting and have nice thick seals. They are big in Europe might even be factory on Ferrari and lambo and other high end cars but they don't think make them for our fourth gens. Think they do for the newer Corvettes though.
But not going to lose sleep about oil getting on the Maf . Can just clean the maf if get a code and clean it yearly or couple times a year its fast and simple to do.
But did have a bitch of a time getting my maf into that SLP lid. I did heat it with hairdryer like they recommended but think if was going to use it again would heat it with heat gun but would have to be more careful with that.
I would think though after the maf has sat in the lid for awhile it will get looser as right now dont' see why you even need to put the supplied clamp on it.
As for ruining mafs not overly worried and mafs are pretty simple to clean. Use qtips and rubbing alcohol being very careful on the resister wires they are thin and bit delicate
or use spray made for cleaning sensors. Its best to take apart the maf since the screen will be in the way unless you have descreened it or have other type like granatelli that has no screen. You need a torx to take apart the maf.
Also found a plug for the lid at napa can give part number for that maybe later today. I plan to remove my air pump stuff. I should have just ordered pre 2000 lid as guess they don't come with a hole but when ordered wasn't sure was going to remove the air pump stuff.
But it does clean up the engine quite a bit making it much easier to change plugs as well.
Also seen some posts where think guys had trouble with lid popping open . The trick is to tuck the slp lid inside the factory lower lip. Then it shuts good and stays shut.
Chad
