cleaning out a super victor
Old 09-12-2014, 12:31 PM
M.BOZZ's Avatar
Default cleaning out a super victor
Is it worth having a super victor intake cleaned ( gutted ) out. How much flow or hp would I gain ?
Old 09-12-2014, 06:12 PM
M.BOZZ's Avatar
anyone ?
Old 09-12-2014, 07:02 PM
LS1-450's Avatar
Would not.
Knock down high casting ridges, yes. Gut it (open up the runner), no. 40 grit for me (no more than 80 grit), by hand & knock down the ridges. For sure don't want to smooth the runners, they need to be rough so that fuel doesn't stick to the walls.
Old 09-12-2014, 07:18 PM
M.BOZZ's Avatar
Is that because of the straight runners ? I should have said this is for a fuel injection not carburetor
Old 09-12-2014, 08:02 PM
LS1-450's Avatar
Fuel injected w/8 injectors in the stock location or injected @ butterfly valves atop the manifold?
Yah, if injectors mounted in the stock location @ head (1 injector per runner, 8 total), then you can smooth the Victor runners, but don't open 'em up, just remove ridges & then smooth. If the runners are opened up too much, air flow will slow down & result in less air to the combustion chamber.
Unless you can log airflow, MAP & A/F ratio & have confirmed that your engine is restricted by the Victor intake runner size, it's best not to open up the runners for the reason noted. The Victor is excellent out of the box & in most cases there's no need to open the runners. Smooth & remove ridges; port match if needed.
Old 09-12-2014, 08:10 PM
handyandy496's Avatar
Did it turn out as good as the Mast?
Old 09-12-2014, 08:26 PM
M.BOZZ's Avatar
Yes, 8 injectors at stock location
Old 09-12-2014, 08:28 PM
M.BOZZ's Avatar
I've looked at the mast intake and wow, nice work. But that would be a over kill for what im doing
Old 09-12-2014, 08:29 PM
Old School Heavy
speedtigger's Avatar
Your intake manifold and cylinder head intake port need to be looked at as one unit. The goal being to create the optimum balance between flow and velocity for your displacement engine as it operates in your target RPM range.
Increasing the cross sectional area of an intake manifold port that already flows more than your cylinder head will likely hurt your average horsepower more than it will help your peak horsepower. Without either a flow bench or flow bench experience with the particular heads and intake you are working with, it would be difficult to determine if a given intake manifold should be enlarged to work with a given set of heads.
The ideal scenario would be to flow bench test the intake port of the cylinder head and then again with the intake manifold bolted on. Then you can evaluate your total package and know what really needs to be modified. You would be able to see the true effects of changing port taper and cross sectional area.
Old 09-12-2014, 08:45 PM
M.BOZZ's Avatar
Well I was looking into getting the heads and intake ported ( matched ) as one unit. Rpms 7,500 or so. Im planning on using the ls1 head not the ls3 head. I was told that my displacement ( 408 ) would work well and not needing the ls3 heads for my range
Old 09-12-2014, 09:20 PM
Old School Heavy
Sounds like a fun engine. The factory cathedral port castings in the right hands have done great things. Are you going to start with 243/799 castings?
Old 09-12-2014, 09:30 PM
M.BOZZ's Avatar
799 with 2.08 intake and the 1.6 exhaust
Old 09-12-2014, 09:54 PM
Old School Heavy
solid roller?
Old 09-12-2014, 10:18 PM
M.BOZZ's Avatar
Yep, something around 260/270 duration and up to 800sh lift. Not real stuck on that but something in that range and a small shot of gogo juice
Old 09-12-2014, 10:19 PM
Old School Heavy
Damn lift.
Quick Reply: cleaning out a super victor
