CA/NJ emissions....
CA/NJ emissions....
If I slap kooks LTs, catted high flow y pipe and borla cat back what are the chances of me passing the sniffer? My instincts tell me none. Would it be simple enough to swap stock y pipe and catless back on if needed for inspection?
With lts and cats you can pass the sniffer with a tune, but you will not pass the visual and its getting harder and harder to get a dirty smog. You would have to swap to stock exhaust manifolds and y pipe to pass.
Although like blueshark said, I don't think NJ does an actual sniffer test. Just OBDII check and possibly a visual. As long as they don't look underneath the car, your setup will pass the OBDII check just fine with the right tune.
