SLP customer service is failing me
Car in sig bought a SLP lid probably 3 years ago. Noticed my idle was acting crazy and found what looks like dirt in my oil when I checked it. Start checking around and my lid is broke around the IAT I think it is sensor. Luckily I have my original air box assembly. No big deal really I thought, it happens its got a warranty. Yeah, I haven't had the best of luck with that. I have emailed and called. No luck, finally got a hold of someone in the warranty department, but apparently its the wrong warranty department. Anyways, I am just a little agitated. Been about two weeks and I am just to the point of buying another air lid and giving up on SLP. May come off as being a lil bitchy, but at this point coming up with a $100 for another lid is pretty hard to do.
LS1Tech Premium Sponsor
From what I have gathered, I have not seen a specific warranty on the SLP lids. They do have a material and workmanship warranty. Basically they would inspect the product and if it looks like a manufactures defect then they will either fix or replace the part at their discretion. A crack in the plastic, especially around an IAT sensor can be caused by the customer by bumping the sensor hard while working in the engine bay or forcing it too hard when popping it in. I'll be honest, I don't see them covering that. If it were me, I would simply plastic weld it from the inside or use epoxy to seal the crack and call it good. I wouldn't buy another intake.
Lonnie
Lonnie
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Yeah it says "limited lifetime" on their website. The main frustration is not even being able to get in contact with them. Funny how when I quit hitting the warranty button on the phone I got a hold of someone easily. Its crazy because I check everything under the hood about once a week along with checking oil etc. I have been busy and started a new job and haven't even opened the hood in about a month and I noticed the idle and bam! its cracked. I sure do appreciate you responding. Really means a lot for you to take your time to respond. I thought about using some epoxy but the way it looks and the position of it when its on the MAF sensor its kind of a bad spot that goes into the IAT sensor I just wasn't sure about repairing it and if it would hold up. Here are a couple pics I think it was coming off the MAF sensor once I got it off the car.
Even if SLP replaces the lid on warranty, you'll likely have to pay shipping to and from SLP. That would probably be at least $30-$40 in shipping costs. Pay $5 for some sort of epoxy or plastic weld kit to seal the lid and be done with it.
