Plugged EVAP Choking Engine Down
I just installed a FAST 102 on my 01' TA and i got rid of the EVAP. When i plug the port for the evap on the driver side of the intake. My motor Bogs almost instantly. Is this due to crankcase not venting properly?? I know i need a tune but it shouldn't bog it that quickly by just sealing the vacuum leak. Any ideas of what to do or why it may be bogging down?
Your iac may be maxed. Try cracking the tb some and resetting the tps or take it to someone that can adjust it for you. You may need to notch the holes on the tps so the voltage doesn't go to high.
