98 z28 camaro/Upgrade throttle body and fuel pumpalong with upgrading fuel injectors?
I would like to know the best route for upgrading my fuel system. I am upgrading the stock fuel injectors to FAST 36lb/hr injectors. Should I leave it at that, or upgrade both the throttle body and fuel pump? What else should I upgrade along with fuel injectors?
What other mods does the car have? Unless this is a heads and cam motor there is no reason to replace the injectors. A Racetronix fuel pump with hot wire kit should be good for most cam only motors.
It's a stock engine, really. The only modification is to the exhaust. Do you think i should even go the fuel system upgrade route, then? I still am going to use my camaro as a daily driver but I want the extra hp (figuring the fuel system would be the least expensive) for when I open it up... have a little fun every now and then.
You could upgrade the fuel pump and fuel pump wiring, I've done that only because my fuel pump was failing so I upgraded. Replacing the injectors would be pointless plus you would have to have the car tuned before it would even be safe to start the car. Don't worry about injectors until you at least have cam, and even then you may get by on stock injectors.
Port and polish your stock throttle body, that's usually good for a few HP. Upgrading the injectors on an otherwise stock engine is pointless. Save those if you plan on doing a H/C swap in the future.
Any particular reason why you want to upgrade the fuel system?
I have an SLP air lid, yes. I didn't feel much a difference, unfortunately. I'll definitely look into the others you mentioned. Like I told American Psycho, I'm simply experimenting with small upgrades. I appreciate any insight you guys have!
^^Nope 98-00. Also there is a upgrade for the PCV valve, it's swaping to a LS6 valley cover with built in PCV. It wont give you any HP just less oil in you intake manifold.
Do you have a Web page I can see it at in a 98'? I was looking it up but only saw the tube by itself. Thanks, I'll definitely look into that!
Auto. Do you have any specs or a brand to recommend? I have the y-pipe, haven't invested in the long tube headers yet.
