Fan operation?
Fan operation?
Before you scream at me, I've searched high and low and found a ton of different conflicting answers.
How are the stock fans in a 01 Z28 supposed to operate?
Currently mine has the passenger side fan comes on around 225, and shuts off at 21x. Thats all i've experienced with it. I have deleted the underhood A/C components. Today, I replaced the stock fans with 2 derale pushers using the stock fan controls to trigger the relays to the 2 fans. But still, only the passenger fan comes on at what i assume is high speed at 225ish.
That's MISTER MODERATOR
LS1 F-body fan operation:
At low speed, the relays connect the fans in series which puts 1/2 voltage to both fans causing them to both run at 1/2 speed.
At high speed, the relays connect the fans in parallel which puts full voltage to both fans causing them both to run at full speed.
LT1 F-body fan operation:
At low speed one fan runs at full voltage causing it to run at full speed.
At high speed, both fans run at full voltage causing both to run at full speed.
So I unplugged the passenger side fan and at 235ish the drivers fan came on, I then plugged in the passenger side fan, both were running until it dropped back to 225, then only the passenger side was running until it dropped to 215. I'm gonna say they work fine and I'm just a dummy.
Thanks for the suggestions and insight on how they opperate.
