tr55 spark plugs for 04 gto?
I found a set online for cheap, I contacted the seller and he said they came pre gapped at .59'...is that the right gap? Or should I lower it? Bone stock 04 gto with 139k on the clock.
Such things are often a loose guide, why would you want such a small gap with a copper plug when we know old distributor setups with less coil potential are fine with larger gaps.
Not to mention OEM plug guidelines are for 100k tuneup interval and have to leave some room for gap erosion, not saying TR5 is a bad plug choice, just saying there is more to understand than you are even willing to consider.
