Junkyard 5.3 w/out pcm
Bought a junkyard 5.3 without the pcm. Made a deal with the guy so I can take whatever else I need from the yard to make it run. What do I need to get? Just a harness and pcm from a different truck? I tried looking it up but couldn't find anything. Thanks
Tell us in detail what your plan is ? What combo are you going to use transmission , accessories , intake , exhaust manifolds and such. If the money is close to the same , you may better off to return that 5.3 and just get a complete pull out engine harness pcm and trans . To completely remove the harness cleanly, unplugging not cutting any thing , in the yard took me over 2 hours my first time. I could do it faster now but , you may want to take a buddy with you to help it go faster. Its easier to just leave the harness connected to the engine do your unplugs from the tranny and body and go with it. The benefit to this are many, it will save time and you know its a match . Complete pullout is the way to go if you can . when you add up buying the alternator , starter , maf and such it starts add up real quickly.
Everything is on the motor except the pcm.im gonna use a ls intake ls6 cam stock manifolds. Probably turbo it next year. Want to try and use my stock 4 speed but if the doesn't work I'm gonna buy a t56. And anything that isn't there the owner of the yard said I can come back and take. I haven't looked at it yet so I don't know if the harness is on it or not. I'll repost when I get it next week.
Yup Thats the plan anyways. I know I'm going to have to make some adjustments or use other accessories. I'm not too worried about that. I just wasn't sure about the pcm and harness working from another truck. its getting tuned anyways I just wanted to make sure the 0411 were all the same for those years
