High end oil filters examined - Page 6 - LS1TECH
Thread Tools Search this Thread
Old 09-15-2016, 06:56 PM   #101
That's MISTER MODERATOR
Paul Bell's Avatar
I think you're out of luck. Wix has high flow filters with the correct thread (13/16-16) but the diameter is too big. The "correct" filter is 2.9" in diameter. I suppose you could measure the filter pad or get one and see if it fits. It's too bad, the Wix racing filters are probably the highest flowing at 60 microns media.
Moroso has a "high flow" filter at 27 microns, # 22462.
Paul Bell is offline   Reply With Quote
Old 09-15-2016, 09:39 PM   #102
sillysspeed's Avatar
Yep that's a bummer. I don't see a listing for the Fram HP filters. Looked at R2C and they don't have a listing either
sillysspeed is offline   Reply With Quote
Old 09-15-2016, 10:07 PM   #103
Paul Bell's Avatar
Quote:
Originally Posted by sillysspeed View Post
for drag racing
You could get an aftermarket oil pan that has no oil filter pad. This eliminates those tiny passages the oil takes through the filter pad. You'll need external lines and a remote filter mount-and you can use any filter you want.
OR, keeping the stock pan, just an oil filter relocation kit.
What I did:
Old 09-16-2016, 09:17 AM   #104
That's a nice setup Paul! On my next engine I will probably go with a remote setup. For now I'm gonna give the moroso filter a try along with Eneos oil.
Old 09-19-2016, 01:32 PM   #105
Default Change intervals don't matter with racing filters...
Does anyone have the part # for Wix racing oil filter for LS1? Did a couple searches with no luck? I'm looking for the highest flowing filter possible for drag racing. I know I need to change it often
Please note that racing filters of ANY type are built for minimum-restriction - meaning their micron size is much wider than a street filter. It passes big particles from the very start. This applies to all filters using a "flow-through" media.
It matters little how often you change your oil and filter. Racing filters are designed for engines that only have to survive a limited amount of time / miles between total rebuilds - NOT oil changes.
If you are a big NASCAR team (or equivalent) that routinely rebuilds their engines after every race - a racing filter is fine. If you are a privateer or small team that does not automatically rebuild, then I would not recommend a racing filter.
As a point of note, I have seen privateer outlaw racing teams that use standard WIX street filters with absolutely no problems or complaints.
damec70 is offline   Reply With Quote
Old 09-19-2016, 02:30 PM   #106
Paul Bell's Avatar
Welcome to LS1tech!
Quote:
Yes, this is correct and has been discussed many times here.
Old 09-20-2016, 07:47 AM   #107
Thanks for the feedback and welcome. While I don't agree with everything you stated I do appreciate your input.
Old 09-21-2016, 12:28 PM   #108
Straight from Wix Tech line: "Don't run the XP unless you do a bunch of start stop. The regular Wix filter does a better job on filtration"
CC'ed from Bob is the oil guy:
Hummm ... WIX XP shows "Beta Ratio: B2=20" for the XP.
That pretty much sucks, as that equates to: "50% efficient @ 20 microns".
The non-synthetic 51516 shows "Beta Ratio: 2/20=6/20".
http://www.wixfilters.com/Lookup/Par...spx?Part=51516
That equates to:
"50% efficient @ 6 microns"
and
"95% efficient @ 20 microns".
B = Beta Ratio
(B-1)/B X 100 = Efficiency %
Beta Ratio --- Efficiency %
2 --- 50.00
5 --- 80.00
10 --- 90.00
15 --- 93.33
20 --- 95.00
25 --- 96.00
30 --- 96.67
40 --- 97.50
50 --- 98.00
75 --- 98.67
100 --- 99.00
125 --- 99.20
250 --- 99.60
500 --- 99.80
750 --- 99.87
1000 --- 99.90
I will be putting standard Wix on mine.
Blackhatch is offline   Reply With Quote
Old 09-22-2016, 06:38 PM   #109
Paul Bell's Avatar
Quote:
Originally Posted by Blackhatch View Post
"Don't run the (Wix) XP unless you do a bunch of start stop.
huh. As they're all similar in design and components, I suppose this would apply to all the filters noted in post #1 here?
Well that's a pretty good choice!
I will continue to choose the Wix XP for all my vehicles.
Old 09-23-2016, 07:04 AM   #110
They are virtually identical. The XP filter is the same filter body and components with a synthetic media vs. a more traditional cellulose media.
The statement from the tech line resource at Wix (this is also echoed in the data above) is that the XP is a better filter if you are doing a bunch of short trips and start stop.
The fact that the standard Wix has a better filtration and capture rate means that it will keep the oil cleaner as a comparison.
Both are good filters, but if you aren't doing a bunch of stop and start driving...you are just spending more money than you need to.
Old 09-23-2016, 08:08 AM   #111
Paul Bell's Avatar
Actually, my DD truck does do a lot of stop & start, from sitting in hours of traffic every day to re-starting as much as 35 times a day when I'm busy.
What do the makers of the other filters say?
Related Topics
Thread Thread Starter Forum Replies Last Post
Anyone in space coast able to cut my fender supports? Mike Morris Florida Members 0 03-08-2017 07:18 PM
'02 f body connector...recognize this?? GonHuntin Conversions & Hybrids 5 02-16-2017 11:47 AM
Since German Castrol is gone.... (IT'S NOT!!) Paul Bell Generation III External Engine 209 04-15-2016 11:53 AM
Special crimper? axekick PCM Diagnostics & Tuning 5 03-24-2016 07:03 PM
Brand new GT45 turbo w/vband and flange cullen Parts Classifieds 5 02-07-2016 06:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
