Wiring coils to toggle switch
I want to wire my coils to a toggle switch. I would run a basic toggle switch and relay circuit, with the power wire going to the positive terminal on each of the two coil connectors. Is there any harm in doing this?
If you're wanting to do this for a kill switch it would be easier to wire it to the fuel pump instead of coils. It would be really easy to splice into a fuel pump "hotwire kit".
One thing you never want to do is cut ignition without cutting fuel. If you cut off only the ignition the exhaust fills with mixed unburned fuel, when the ignition comes on you will have a explosion in the exhaust. Even a few seconds of no ignition with the engine running will fill the exhaust with perfectly mixed fuel, You can guess the rest.
I built a portable power unit with a 500ci caddy engine a long time ago. It was used to turn large fans in the field to test dampers for coal fired power plants. The fans only turn 1800-2200 rpm max so I used a rpm tach that gets connected to the coil that starts cutting out ignition near the preset rpm. Well it never mentioned the disaster that follows cutting off the ignition but not cutting off fuel. The 1st time it hit the rpm limiter THE ENTIRE EXHUAST BLEW OFF THE POWER UNIT. It was so loud and crazy we had no idea what the hell just happened. Luckily no one was hurt, I unhooked the coil control and never used the rpm limiter again.
The factory rpm limiter uses the timing pulling it back as you get near the rpm limit then if it's still not enough it starts pulling fuel.
I had a friend that had an old truck and he would turn off the ignition while driving pump the gas and then turn it back on. It would sound like a bomb going off. Truck was manual. He would probably get arrested today. He did finally blow the muffler off.
LMAO, We did that as teens all the time back in the early 70s with 50s/60s cars, specially to scare people walking on the footpath
OP, wire your switch into the PCM power supply instead of the coils or injectors. Then you have everything you need killed, safely.
