Short Water Pump Pulley
Clearance is very tight. I need about another 2" for radiator clearance; that Liberty Bell pulley is ridiculous. Otherwise I have to completely redesign the cooling system mounts. I can do that, But I'd rather just replace the water pump if I can.
I'm using F body front drive accessories, with power steering but no AC. I could change to Corvette stuff, but that's a lot of expense. The word "Corvette" in the title adds 20%.
I'v done a bunch of reading, and this is what I think I know:
- the LS2/3 pump is certainly closer, but makes belt alignment a little iffy.
- People have pulled the LS2 pump out on the shaft about 3/8", and then welded the pulley to the shaft
- What about a 3/8" spacer for the water pump? IMO, a better long term solution.
- The Edelbrock pump is only about an inch shorter.
- The Evans Cooling pump seems to be about 2" (maybe 2.5") shorter, and works better at high rpm's. Except for the cost, I'm liking this.
-- anybody use one?
-- is it really that much shorter?
Any other options available?
-- anybody use one?
Water pump pulley interferance
Has anyone used this set up, I have no room to spare for my radiator and fans. I have removed the acc. from my LQ9 and installed f-body p/s pump and alternator but the factory water pump shaft and pulley protrude out too far. Any one run or know of a shorter pump for the f-body set up? Thanks
The water pump is ACDelco 251-728; used in a lot of vehicles.
It is installed with the 3/4" spacers, you can sort of see them in the second picture. I also plumbed the head steam vents into the left side spacer. It was already drilled and tapped for that.
I did cut the outlet down for more space. Notice that the oultet is in a different place than the LS1 pump.
I would have preferred to use the closer fitting LS1 Corvette drive system. But it sticks out to far, and would hit the driver's side frame rail. To go that route, I'd have to eliminate the P/S pump; and for a number of reasons I didn't want to do that.
Fitting all the cooling components on this car has been a pain in the neck. I had to try 3-4 different iterations to find one that would work.
Not an Edelbrock. Bought it on eBay and since Edelbrock doesn't make water pumps, probably the same pump rebadged.
I ended up buying a 3/4" spacer then milling it down to 1/2" so I could get maximum clearance. That put the belt on the outside edge of the pulley, but no concern there. Also cut down the Katech tensioner accordingly.
