oil pan cracked help!!!
Alright guys so I just found a big puddle of oil when I took my car out of the garage. I wanted to see what is a good oil pan that will have oem fitment,I have a stock k member if that means something when dealing with pans. I was also wondering if there is a step by step stickies on how to do the swap out since in Wyoming they charge a s*** load. Thanks for yall help
Honestly I don't know how it cracked...when I got under the car I saw a line going truh it...and I don't need and aftermarket one like u said...does anybody now where I can find stock ones by any chance
Street & performance has take off pans. You didn't say what vehicle, should we assume 98 to 02' f-body ?
Another option would be draining, clean , scuff, reclean & use jb weld over the area. If done right , it will work wonders. Temporarily fixed a few spots on my gas tank for over 20 years now, guess it's done ok.
Just need proper prep & application, it will stick like hell to clean rough aluminum.
I got my replacement f-body pan (if that's the vehicle, anyway) from Summit for ~$220.
You have to lower the K member and raise the motor. I did it alone with no problems thanks to a little research on here. There's several threads with tons of info.
This thing was also a big help.
http://www.harborfreight.com/1000-lb...bar-96524.html
