Question about Cats and Exhaust
to my question on Cats.
Does it matter how far away from the motor they are? Do they function differently right off the manifold or a few feet back in the system?
Im SO TIRED of being gassed out, tuning helped but I just need cats.
the only place they can go on my system is here-
I think I can make them fit there but is it too far away and would I just end up clogging them or something?
I know they need to get hot to function properly but dont know if they will got hot enough that far back especially since I have headers that run cooler anyway.
let me know cause i dont know much about cats.
So literally my only option is what I posted or I guess I could cut off the collector and weld them there but id rather not do that. Do they get ruined if they arent hot enough? or do they just not filter as well?
I ran into this same issue when doing headers and true duals. The shop said they would eventually clog if too far back. The cut off part of the header, welded one in there to get it close.
Im not even sure if thats an option on my system because they would literally have to cut off the whole collector using the smallest cat ive been able to find. I wonder if it would work if I found a stainless cat and then ceramic coated it or wrapped it to keep the heat in. bad idea?
not sure what state you are in, so I don't know what kind of inspection you have to go through, but the federal law (EPA) says that cats must be within 3 inches of where the factory put them and you have to have the same number of cats as the factory installed.
Im in utah but the xpipe would be where they were from the factory. so I guess mine would be about 10 inches from where they were. I have friends that pass me so I highly doubt ill have that problem. My main concern is just not wanting to install them and go through all the hassle if they are just going to clog up from not getting hot enough farther back in the system
Just got off the phone with an exhaust shop. They said its ok if the Cat is further back in they system, it will just take longer for it to "light". but it wont cause it to clog.
So basically on cold start ups it will still think ect but once Its been running/driving for a bit it should heat up enough to start working
