Stainless TSP TD mounting questions
Ive been wanting to try these for for awhile, decided to pull the trigger on some TSP 1 7/8 stainless long tubes and the True duals to match. The header fitment was excellent, the true duals, not so much. Ive done a few searchs and cant come up with my answer, im assuming i have the X flipped, the mufflers angle down about 6" lower then the floor pan where the rubber mounts are to go on. the rear mufflers are 8-10" out from the floor pan(close to the rear) did anyone need to cut the exhaust after the X to bring the mufflers in to a manageable distance? the only issue im thinking is the collectors on the TSP 1 7/8 LTs are too long, the True duals are seated completely on the collectors. Any help or input??
