ls1 power gains off 243 heads alone and or Fast 90
Old 02-14-2015, 06:54 PM
GMW96's Avatar
Default ls1 power gains off 243 heads alone and or Fast 90
I have seen posted intake and heads or cam and heads dyno comparisons. I have a 04 GTO LS1. I have a cam and long tubes. I have the stock ls6 intake manifold. I just got dyno tuned on a dyno jet and made 370/370.
First question is would it be possible to hit 400whp with stock 243 heads? 2nd my tuner said I could hit over 400whp with a fast 90 on my current setup. Do these intakes really flow that much better?
Old 02-14-2015, 07:31 PM
HCI2000SS's Avatar
You probably won't gain 30 hp on your setup with just a Fast intake alone
Old 02-14-2015, 07:35 PM
atahtz28's Avatar
There has been lots of debate on the Fast brand of intakes and comparing them to a stock ls6 intake. Since you have a cam you'd probably see around a 15hp/tq increase with a Fast 90 but it depends on your cam specs. Now, if you bought a Fast 90 and had it ported as well, then you'd be looking at a little more power even.
As for 243's I think people generally see 15-25hp/tq increase over stock without a tune. Now with a tune after installing 243's you'd probably hit that 400hp/tq mark you're looking for. Porting these would also help even more too but that requires more $$$.
A Fast 92 or Fast 102 may even be beneficial to your set up. I say everything depends on your budget and cam specs though, just my .02$.
Old 02-14-2015, 07:55 PM
george g's Avatar
I hit 415 with stock 243 heads,profesional products 85mm intake&tb,ls2 maf,small cam and pacesetter lts.
Old 02-14-2015, 07:57 PM
GMW96's Avatar
Thats good to hear. Those Fast intakes are pretty pricey.
Would the Fast 102 be too big for this motor being a 5.7? So the 243 heads are the better bang for buck? Will stock injectors support this? I have a 255 fuel pump.
Old 02-15-2015, 12:01 AM
atahtz28's Avatar
Some people say a Fast 102 is too big, but normally it's only too big if you have a stock cam. Since you have an aftermarket cam it's a toss up depending on your specs i'd say.
I'd say 243's are the best bang for the buck because you can find some for around 400$ as where a Fast intake is really expensive. But as for injectors that's close to border line I think, people have run stock injectors up to 450hp, others say to upgrade to at least 30# injectors. The stock injector size is 28.8# I think. Hope that helps a little.
Old 02-15-2015, 12:16 AM
Super Hulk Smash
JakeFusion's Avatar
Vengeance posted in the Dyno forum the other day. FAST 102 was picking up like 25/22 over the LS6.
Stock 243s will pick up about 20rwhp. So the FAST may pick up more. However, ported 243s will pick up probably 40-55rwhp depending on compression and port job quality.
My advice is to do heads first. Always. Even ported 5.3L heads will pick up 40rwhp over stock LS1 heads. Then pair with the FAST. Budget heads + FAST will out power aftermarket heads + LS6 intake for the same price.
Old 02-15-2015, 11:30 AM
GMW96's Avatar
Thanks my hunt for 243 heads begin now!
Old 02-15-2015, 01:20 PM
GMW96's Avatar
Just got some 243 heads!
Old 02-15-2015, 03:53 PM
atahtz28's Avatar
That was fast! Hope you hit your 400hp mark
Old 02-19-2015, 11:52 AM
gagliano7's Avatar
What heads come on the gto? I thought they had the 243 heads.
Old 02-19-2015, 12:03 PM
thunderstruck507's Avatar
No way I would ever expect over 15rwhp from stock 243s. You might get a tad over that if you're lucky. They shine when ported but as far as stock I would have a hard time justifying the cost/labor.
Old 02-19-2015, 12:04 PM
HCI2000SS's Avatar
Yes that's right
Old 02-20-2015, 02:02 PM
CGCBandit's Avatar
Yes that's right
not the 04's. The 05-06 LS2 cars have the 243's
Old 02-20-2015, 03:05 PM
HCI2000SS's Avatar
Good catch. I missed that, and just assumed the op had a 6.0
Old 03-02-2015, 03:13 PM
GMW96's Avatar
Never posted my cam specs 233/239 113.
Old 07-23-2015, 05:18 PM
GMW96's Avatar
I am going with stock 243's and hope that gets me close or in the 400whp club.
Old 07-23-2015, 07:14 PM
waybad's Avatar
love too see the final add of horsepower with just the heads alone!!
Old 07-23-2015, 07:22 PM
kinglt-1's Avatar
Trus me It's not worth all the work to swap stock 243's for 15whp. Pony up and get them ported and gain 40-50whp. Hell you would pick up the same or more buying a used fast 92 and swapping it compared to stock 243's. Be a much easier swap too.
Old 07-24-2015, 12:59 AM
lowazztruck's Avatar
I had a 04 Gto. Stock 243s just milled. Cam and fast 92/92. Through an auto with 3600 stall made 420whp
Quick Reply: ls1 power gains off 243 heads alone and or Fast 90
