Oil Pan Bolt Leak
Oil Pan Bolt Leak
I recently did a h/c swap on my car and went through it and replaced all of the gaskets, the oil pan being one of them. After i got everything back together and ran the car for a day or two I lifted it up and noticed some saturation around the bolt holes on the pan and on the bolt heads. It was a brand new GM gasket I put in. Is there any explanation for this what seems to be a leak?
Also I was thinking about taking them out one at a time and re-installing them with some thread sealant that I used to seal the intake rocker bolts. Does anyone have a better suggestion?
I will take another look to be sure but it doesn't seem to be running down from anywhere. I will also try to get some pictures of it as well. Thanks for your input.
Is the oil on ALL of the bolts, or is it only on the rears?
A leak at the front will be sent rearward with the aid of wind at highway speeds.
The engine is on an incline...front higher than rear.
When the gasket was installed, did the installer place a dab of sealer at all four corners?
Try wiping everything off, take a drive, then let everything cool off. This will allow the oil to seep. You may be better able to see what is happening.
