Bolts keep coming loose on Fast 102 intake?
Just wondering if anyone has this problem and how they solved if? Most of the time it's the front ones that are closest to the TB that holds the upper and lower pieces together. But I get some turns on some others too.
I followed the torque specs and everything. I just put the new motor and intake in at the end of summer and was going over bolts after a couple runs to see if any worked loose. The only ones were on the intake lol. I started having idling issues so I checked the bolts and yep loose again.
Is there something I'm missing? I don't think it said to loctite them but I'm about ready to
I recommend repeating the torque sequence multiple times until all the mount bolts remain at the recommended torque spec. The check it again within 7days.
Fyi, any time I have removed then reinstalled my FAST 92 intake I had to repeat the torque sequence at least 4 times. If you're having issues with the bolts that hold the upper and lower shells together loosing, use blue Loctite on the threads.
I agree with this. I have swapped lots of intakes for LS1 cars be it they are upgrading to the LS6 or an aftermarket intake. I have even reused the factory bolts for those guys to cheap to buy arp bolts or cheap gm replacements. The only way I see the bolts continually coming loose is if the treads are stripped on the bolts are in the heads. Get a 6mm tap and chase the threads in the heads and invest in some new bolts. Use lots of lube on the tap and clean the holes out good afterwards.
